First post, by MrPepka
I have a hard case, I can't cure it, but maybe you will have an idea. The game at startup displays the message "Invalid WDL File", and the game launcher still shows an error that says about too much free virtual memory. I don't want to artificially reduce this memory, I'd like to fix this game somehow. Unfortunately, my knowledge about debugging the game is so low that I am not able to track the correct hex value myself and change it so that the game can see the right amount of this memory
Reply 2 of 3, by MrPepka
Unfortunately, compatibility mode did not help because I already tried it. The game was only started with dxwnd when the run.exe file was set in the Launch path. The problem here is that the game is not able to know exactly where the disc (or disc image) is with it (in which drive) and therefore is not able to hide this disc or the disc image there
