First post, by legion_pheonix
Good day everyone.
Tell me how you can make lotrw.dll work with D3D8.dll from dgvoodoo2 so that there is a widescreen resolution?
    lotr_widescreen.7z
    41.69 KiB
    25 downloads
Reply 3 of 3, by legion_pheonix
Dege wrote on 2020-08-05, 14:49:
Use this.
Good evening. There is a small problem with the cutscenes in the game. If you run without dgvoodoo2, then the videos are visible in the center without distortion. If you run with it, then you see a large strip at the top, and the video is flattened.
I tried to replace the dll files DivxMediaLib.dll DivxDecoder.dll with newer versions. Everything remained the same.
