First post, by MrPepka
This time I need help with running the game "Rendezvous With A Stranger" so that the game can also see the dgvoodoo2 wrapper. A few words about this game:
It is an erotic game which consists in seducing three Russian women and landing in bed with them. The game starts only from CD1, trying to copy it to disk and run it in this way will result in the message that the file is missing, as well as the message "No MCI device open". You can get around this by copying the entire contents of CD1 anywhere on the disk, copying dgvoodoo2 files (you also have to copy them to the folder with the game installed) and creating an ISO image using ISO Creator of the copied CD1 content (the image must be named "Randevu1" and preferably if it was with the letter F), then you need to create a shortcut of the game's exe file, enter its properties and in the Command line line add "1 1 1 9 10 F" to bypass the game autorun. I can only send the game to PW
