First post, by Discrete_BOB_058
When I use dgVoodoo 2, a common problem that I encounter is that the game switches to Windowed mode automatically, even if the game doesn't have the feature. If I uncheck the feature which 'disables the Alt+Enter function to switch to fullscreen', the game will then switch to fullscreen mode using Alt+Enter. However this feature is provided only in DirectX. I have the same problem with a game called Starshot Circus Fever, the game works on both nGlide and dgVoodoo 2 but none of the cutscenes work in nGlide which instead work in dgVoodoo 2. However the game goes to Windowed mode and since the switching feature is not provided in dgVoodoo 2, I have to stick to windowed mode. Could you please add this feature to the 3Dfx mode too along with the DirectX mode?
Or if I am not aware, is there an option to make this function work or at least prevent the game from switching to windowed mode?
YouTube Channel:
DEADHistory Walkthroughs
PC SPECS:-
CPU: AMD Ryzen 5 1600
GPU: ZOTAC NVIDIA GeForce GTX 1050Ti OC Edition
RAM: 8GB*2 Corsair Vengeance LPX DDR4 2400MHz
Motherboard: Gigabyte Aorus B450M
PSU: Corsair VX550
Sound Card: Realtek ALC892
