First post, by lowenz
About STALKER: just put the d3d9.dll (in the bin folder + bat for launch the engine from the root - work - dir) as always.
It starts with no problem but only with static lighting available no matter what you choose in the menu.
Reply 1 of 9, by lowenz
lowenz wrote on 2021-03-15, 11:20:
So, any idea about this behaviour?
Reply 2 of 9, by lowenz
Note: I've already removed from the bin folder "d3dx9_31" and "d3dx9_34" maybe interfering
Shadow of Chernobyl 1.0006, no mods, game starting area
NO dgv2 (right rendering for "Full Dynamic Lighting"):
dgv2 "forced" static lighting no matter the menu choice:
Reply 6 of 9, by Dege
Ok, as it turned out, the game initializes D3D9 from both DllMain and later from regular code.
DllMain fails with dgVoodoo and that's what causes losing dynamic lighting (I guess the game queries some caps, texture formats and such from the DllMain instance).
Experimentally I forced DllMain to fail with native D3D9 and got the same wrong result.
So, I'm afraid dgVoodoo won't work with this game unless the game is patched (if possible at all).
Reply 9 of 9, by lowenz
Well, let's wait a stable release of OpenXRay then!
Will test OGSR too ( if you wanna take a look, OGSR is specifically intended as a "drag&drop" SHoC engine replacement! -> https://github.com/OGSR/OGSR-Engine )
