First post, by KvynB
Hello everyone, I have been playing EA Cricket 2007 since 2018. The game's default API is DirectX 8. I had discovered a way to run in DirectX 9 last year in order to run ReShade and nvidia Profile Inspector through enbdev's dx8 to dx9 converter. But when tried running it in dx11 through dgVoodoo 2, it is running terribly with graphical glitches and low frame per seconds. If use the virtual 3d accelerator then it's graphical glitches with extremely poor framerates like 18-32 fps. And if use the other card versions then it's even worse framerates like 20-30 fps. Used 2.54, 2.74, 2.75, 2.75.1 but still no hope. Used d3d9.dll. Glitches in the photos using the virtual 3d accelerated card.
Core 2 Quad Q6600,Nvidia Geforce GT 730 4GB DDR3 Zone Edition, 4GB DDR2 800MHz, WD 320 GB HDD
