Reply 40 of 59, by BEEN_Nath_58
Dege wrote on 2022-07-05, 10:50:
No, there is no need for dgV DDraw wrapper.
Mechwarrior2 + dgV Glide.dll wrapper with option Glide\ForceEmulatingTruePCIAccess enabled.
Yes he is trying and I am testing without DirectDraw wrapper, some bug turned up again and so he is revising things again. I will update when we reach an agreeable point.
Reply 41 of 59, by BEEN_Nath_58
I finally have a report but it doesn't lead to anywhere. Game wasn't succeeding with disabling guard page handling, so I took a turn, disable DxWnd's exception handler completely. You can try it yourself, put a proxied winmm.dll with a different name, of Windows XP and hex edit WAIL32.DLL to the new file's name. After that, disabling the exception handler will still run the game, but there will be no sound effects, and the game will freeze if you don't hold Ctrl.
And the HUD disappears here too, meaning it probably isn't the guard page. 🙁
Reply 42 of 59, by BEEN_Nath_58
Continuation of previous post: Meanwhile, I managed to load up MechWarrior 2 with nGlide too but there are still problems. I attached screenshots to compare nGlide vs dgVoodoo1 vs dgVoodoo. There is yet another problem untold. When I abort a mission, the menu crashes in dgV2 and freezes to a black screen in dgV1 (also in nGlide).
nGlide:
file.php?mode=view&id=141093
dgVoodoo1:
file.php?mode=view&id=141091
dgVoodoo2:
file.php?mode=view&id=141092
Reply 43 of 59, by Gamecollector
BEEN_Nath_58 wrote on 2022-07-07, 05:13:
Try nGlide 2.00.
Reply 44 of 59, by BEEN_Nath_58
Gamecollector wrote on 2022-07-09, 18:08:
Try nGlide 2.00.
It almost made it. Almost! Issue is when playing the game, you cannot use the mouse because it takes you to desktop AND the game causes a black screen on 2nd abort of a mission.
Another good news, for Mr. Dege was dgVoodoo2 actually ran once today, until it no longer worked the same way again. Again, there is another small work left on dgVoodoo2, the game crashes on aborting a mission. Can you fix this?
Reply 45 of 59, by Dege
You mean the HUD has suddenly become correct with dgv2? How can that be? (how could be wrong...)
Also, as far as I remember, the game didn't crash for me when returning from a mission to the main menu, or quitting to Windows.
Reply 46 of 59, by BEEN_Nath_58
Dege wrote on 2022-07-12, 12:08:
I wish I knew the answer, but the game behaves so inconsistent and absurd even ghotik struggles to just run the game on his PC. Regarding the menu, I think it's again a "you" problem in my part (games can't find msvcrt.dll and such even when they are installed and dosbox crashes in any programfiles folder). I think I will wait for my Windows reinstall and retest it.
Reply 47 of 59, by Deffnator
Just small tidbit
years ago mech2.org did a windows widescreen patch for mech 2win, it must be at their discord.
it was a exe file that tweaked the game's resolution to any res you wanted, even 4k 16:9
Reply 48 of 59, by myne
If anyone wants a working and simple dosbox (software) version of this:
LINK REMOVED
Things I built:
Mechwarrior 2 installer for Windows 10/11 Re: A comprehensive guide to install and play MechWarrior 2 on new versions on Windows.
Dos+Windows 3.11 auto-install iso template (for vmware)
Reply 49 of 59, by DosFreak
Link removed.
So called "abandonware" is not supported here. Please peddle this crap elsewhere. Thanks
Make your games work offline
Reply 50 of 59, by BEEN_Nath_58
@Dege
And so I installed Windows 11 22H2 and guess what, the HUD now loads perfectly! Except there is one thing still left.
The game still freezes/crashes at a black screen after a mission exit. I installed the game as the first application after OTVDM, so it can't be anything else interfering.
Reply 51 of 59, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2022-09-20, 19:23:
@Dege […]
@Dege
Oh wait the problem is still there:
file.php?mode=view&id=145941
The problem will arrive only if I enable Resolution 800x600. I think that can be fixed easily by you.
Also that crash after exit happens without DxWnd DirectX interference so it must be something else, maybe related to DirectDraw/Glide to GDI surface transformations... (the game GUI uses GDI).
Reply 52 of 59, by Deffnator
BEEN_Nath_58 wrote on 2022-09-21, 13:52:
Oh wait the problem is still there: https://www.vogons.org/download/file.php?mode=view&id=145941 […]
@Dege […]
@Dege
Have you tried to check it out the widescreen patch at moddb?
they managed to edit the VESA dll files so the game can reach widescreen res.
also there is the old mech2.org resolution tool that permitted you to play in fullhd, i used that back when the game still worked on win7.
i think that tool is still around at their discord, try to reach them there.
Reply 53 of 59, by BEEN_Nath_58
Deffnator wrote on 2022-09-27, 21:05:
Have you tried to check it out the widescreen patch at moddb? […]
@Dege
The problem is it is for the DOS version, and we are using a Windows game...
Reply 54 of 59, by Deffnator
yes and mechprep made by kontza worked on winmech and winmercs
sadly mech2 website is dead, but they probably has all of the tools on their discord.
you could use mechprep to increase winmech to 1080p+ i used it a lot back in 2010 to play mech 2 and mercs 3dfx.
i am saying this because if they still have at mech2.org discord they may even help you and dege about solving this issue.
i will ove to see all windows versions of mech2 and mercs working in W10+
Reply 55 of 59, by BEEN_Nath_58
Deffnator wrote on 2022-09-30, 13:27:
yes and mechprep made by kontza worked on winmech and winmercs sadly mech2 website is dead, but they probably has all of the too […]
The 22H2 update messed some things up with how the "compatibility modes" work in this game, but nevertheless I will continue on it.
@Dege Good to see you back 😊. I have tracked the problem as you can read above, and it only happens on 800x600 resolution setting.
Regarding the crash on exit, it still happens...and yes I reinstalled Windows.
Reply 57 of 59, by BEEN_Nath_58
Dege wrote on 2022-12-21, 20:14:
It's embarrassing but I finally found a bug in dgVoodoo. At least I fixed it (see WIP89.1), now it should work in 800x600 too.
Yes it is working. Thanks, the problem is fixed.
Reply 58 of 59, by BEEN_Nath_58
Back with this thread. I found yet another bug:
If I choose a resolution in dgVoodoo2, say Desktop, or 2560x1440, the HUD colours are messed up
    795.01 KiB
