First post, by zekkah
Greetings,
I registered so I could find out if there is a solution for this problem: Populous: The Beginning crashes with fast memory access turned on. The game works if I turn it off, but alot of the textures become white (I heard it's a problem with AMD GPUs).
I was wondering if it's possible to make the game work with fast memory access.
Thanks in advance.
