First post, by Joachim
As soon as DirectX-Resolution is not "unforced", for example "Desktop", the mouse does not work correctly for the in-game menu, the cursor disappears. You can still click the menu option if you know where your mouse should be. That problem has been there since ever, but I never reported it. It may apply to Tiberian Sun as well. Cannot deliver screen-shots here since ALL screen-shots from that game exclude the mouse cursor - even with Bandicam.
The easiest way to get DGVoodo in TI is to unpack the attached .7z file in the fully installed and updated TI folder. It will add DGVoodoo as normal rendering option to the menu:
file.php?mode=view&id=153566
To reproduce: Run dgvoodoocpl.exe from "Twisted Insurrection\Resources" sub-directory, NOT the one you may find directly in the "Twisted Insurrection" directory, and change "DirectX" "Full Screen Output" to something else than "Default", I use "Desktop". Then start a mission, hit ESC for the menu and try "abort mission". The mouse will disappear as soon as you enter the menu area. Setting the DGVoodo option back to "Default" and it will work as it should. Please note: You really need to start a mission, not just stick around in the launcher which is just the TI front-end.
Why DgVoodo for TI?
1. I can set the brightness there. TI is often WAY too dark, 140% brightness via DGVoodoo helps a lot. With some maps you need 170%!
2. I can (or rather would love to...) use Point-Sample stretch, to keep the original blockiness instead of a filtered something on this large 4K screen. Tactically important to really see every pixel so you can distinguish your own infantry types.
If there is already a possible line for the .conf which might help, just tell and I test!
Reply 1 of 3, by ZellSF
If you're just looking to get it working how you want, regardless of software I can suggest an alternative:
cnc-ddraw in windowed mode:
https://github.com/FunkyFr3sh/cnc-ddraw/releases
Plus Magpie 0.9.1 (newest preview release is Chinese only):
https://github.com/Blinue/Magpie
Then you can setup Magpie to tweak the image to look however you want it. For example, here's a slight modification of my ScaleModels.json:
"name": "MyScaleModel",
"effects": [
"effect": "nearest",
"scale": [ 2, 2 ]
"effect": "lanczos",
"scale": [ -1, -1 ]
"effect": "ImageAdjustment",
"luminance": 1.5
Scale nearest integer scale 2x, then use sharp Lanczos scaling to scale to screen and adjust luminance up 150%. That way I get a perfectly sharp, pixelated over-bright image.
I recommend in addition to setting windowed=true in ddraw.ini that you also experiment with the maxgametics setting, without using it some things (like minimap animations) run way too fast, for me somewhere in the 120-240 range seems to be nice. That's also a function dgVoodoo don't have (and probably never will) so it's nice to use cnc-ddraw just for that anyway.
Reply 3 of 3, by Dege
The ingame menu turned out to be a child window over the rendering window. Such solutions are not friend of dgVoodoo, but anyway, I did a fix for childwindow-scenarios.
So, the game now should work with WIP89.3 as expected, see: Re: dgVodooo 2.7.x and related WIP versions (2)
