First post, by ngovandang
I think this water is being "scaled" bigger? Sometime it's fine sometime it's like this, is there a fix for this?
I use default setting, only change scaling mode to stretched, 3:4 and directx resolution max
Reply 1 of 3, by Dege
ngovandang wrote on 2024-01-20, 18:08:
You should set option DirectXExt\RTTexturesForceScaleAndMSAA to false. It's true for all other games rendering the water by the same technique (like Splinter Cell).
