First post, by Parni
I'm having trouble to get Ignition working with the 3dfx patch in Windows 95 OSR2.5 , also Carmageddon 2 gives the same error message (picture below)
Any clue what could cause this? I couldn't find an solution with quick Googlin.
Reply 1 of 9, by Parni
Other 3dfx games works ok
Reply 2 of 9, by Parni
A virus perhaps?
Reply 3 of 9, by Parni
Non 3dfx executable works fine with Ignition
Reply 4 of 9, by TheMLGladiator
Are these the GOG versions, or retail CD?
Reply 5 of 9, by Parni
Retail CD, mounted with Daemon Tools
Reply 6 of 9, by TheMLGladiator
What version of Daemon Tools are you running?
Reply 8 of 9, by Parni
Ok, so Ignition works with the Voodoo2 patch, however there are some weird vertical stripes in the picture
Reply 9 of 9, by TheMLGladiator
Could you post a picture? That may just be the normal Voodoo2 dithering pattern that becomes more noticeable on LCD monitors.
