First post, by WTG_Scoob
I finally got my W98 pc up and running again and I just got a Thrustmaster flight control stick and wanted to try ACES OVER EUROPE but I can't get it running .
Setup :
P3 450mhz
256 mb ram
geforce 2 mx400
32gb hdd
I have tried a few different config and autoexec files i found on here but it still says not enough memory no matter what I do
Reply 1 of 5, by Stretch
In config.sys after EMM386 try to reduce your ram such as:
DEVICE=C:\DOS\EMM386.EXE RAM 64512
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Sound Blaster G8
Reply 2 of 5, by WTG_Scoob
So my pc doesnt have a dos folder mine says c:\windows\emm386.exe
does that matter?
Reply 3 of 5, by Jo22
The game mentioned "extended memory" rather than XMS.. Hm.
On DOS 6.22 Himem.sys, there's an /int15= parameter that reserves Extended Memory for the int15h BIOS interface (func. 87h)..
MSD and CheckIt v3 can confirm that memory, if made available.
http://info.wsisiz.edu.pl/~bse26236/batutil/help/HIMEM_S.HTM
http://manmrk.net/tutorials/DOS/msdos7/himem.htm
Reply 4 of 5, by Falcosoft
WTG_Scoob wrote on 2022-02-18, 02:18:
I finally got my W98 pc up and running again and I just got a Thrustmaster flight control stick and wanted to try ACES OVER EURO […]
Setup :
P3 450mhz
256 mb ram
geforce 2 mx400
32gb hdd
Your problem is most likely is that you have too much extended memory (256MB) that the game cannot interpret properly. So you should try to limit your XMS to e.g. 16MB. You can use HimemX with the /MAX parameter to do this.
https://sourceforge.net/projects/himemx/files/
After downloading and putting HimemX.exe to your windows directory you should put this into the 1st line of your Config .sys:
DEVICE=C:\windows\HimemX.exe /MAX=16M
This limits the available extended memory.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 5 of 5, by keropi
Use the XMS/EMS ramdisk program by Franck Uberto to limit the available memory.
By far the best solution I have tried, not only it can be resized/removed (so great for batch files to launch games) but it can be instructed with /t switch to occupy memory above 16MB - this helps some old games.
I would try like this in your case:
xmsdsk 250000 /t /y
then after game is finished just run xmsdsk /u /y and ramdisk will be completely removed from ram
