font problem under DOS?
First post, by dudulinek
Hi. I just installed SC2000 on my P233MMX + DOS 6.22. Installation OK, game running without any problems. Whats wrong with installer? Can i fix this? See attached image pls. I have same problem with more games not only SC2000.
Same installation diskettes in dosbox working fine.
Ty for any help
Reply 1 of 7, by konc
Try to boot the real pc clean, bypassing config.sys & autoexec.bat to see if the issue persists
Reply 2 of 7, by leileilol
Is it that VBE3.0 killing EGA fonts on newer >98 video cards bug?
FUCK "AI"
Reply 3 of 7, by dudulinek
konc wrote on 2021-08-01, 07:55:
my autoexec.bat
@ECHO OFF
LH C:\DOS\MSCDEX.EXE /D:banana /L:D
SET CTSYN=C:\DOS
SET MIDI=SYNTH:1 MAP:E MODE:0
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET PATH=C:\DOS;C:\DN
C:\DOS\SBEINIT.COM
my config.sys
DOS=HIGH, UMB
DEVICE=C:\DOS\HIMEM.SYS
DEVICEHIGH=C:\DOS\EMM386.EXE RAM
DEVICE=C:\DOS\CD1.SYS /D:BANANA
FILES=50
BUFFERS=30
STACKS=9,256
LASTDRIVE=Z
leileilol wrote on 2021-08-01, 08:16:
S3 Virge DX 4MB
Reply 4 of 7, by Gmlb256
This issue is related to the 8x14 font which was removed on certain video cards as a way of freeing up space for VBE BIOS implementations. The S3 Virge/DX that you mentioned likely have a VBE 2.0 BIOS implementation (which lacks these fonts) instead of the more common VBE 1.2 BIOS.
For these cards you must use a TSR such as FIX8X14 as a workaround. Here is the link for the TSR: https://www.bttr-software.de/products/fix8x14/
Reply 5 of 7, by dudulinek
Gmlb256 wrote on 2021-08-01, 18:01:
OH! Thank you will try 😀
UPDATE: Fix working. Thank you again!
Reply 6 of 7, by Reticular
@Gmlb256 - initially i wanted to thank you because it seemed that your link fixed my "garbage fonts", but they came back very soon. The gpu is S3 Trio 2D/3D 4mb btw
Anyway, what finally resolved corputed fonts wac getting the "Fonts" folder from C:Windows of another w98 installation and replacing mine, simply offloading the files while disk is connected to a different machine.
Cheers
Reply 7 of 7, by Gmlb256
Reticular wrote on 2022-11-16, 23:01:
Cheers
The utility that I linked (works well with the S3 Trio3D/2X video card) only addresses the issue with the EGA 8x14 font which some DOS programs used. The problem that you had was unrelated considering that making changes to the "Fonts" folder located in C:\WINDOWS fixed it.
