First post, by NightShadowPT
As many of you I am going through the struggle of getting the most out of my MS-DOS memory, but due to a SCSI Controller (Adaptec) I am using 2 drivers that are killing my memory:
ASPI7DOS.SYS - Is taking 25Kb of memory
ASPICD.SYS - Is taking an additional 12Kb
And this is before I load MSCDEX that is taking me 16Kb
Are there any alternatives that are less memory hungry?
Also, my Himem.sys seems to be taking 33Kb of Conventional memory... I seem to remember it taking less, but maybe I'm getting old 😀
Happy to hear your thoughts
NightShadowPT
Compaq Deskpro M 486/66 - 64MB Ram - Compaq QVision 1MB - Orpheus II Sound
Card - 4GB SCSI HDD + 4GB CF Card - SCSI CD-ROM Plextor PX-32TSi - Adaptec WideSCSI AHA-2740W - 3COM Etherlink III Card
Reply 2 of 17, by davidrg
Yeah, memmaker will probably fix the problem if you're not loading stuff into upper memory yourself.
I typically run my 486 with around 595K of free conventional memory with just about everything under the sun loaded - himem, emm386, a full network stack (ipx, tcp/ip, network drives), two remote control TSRs, mouse driver, unnecessary Creative TSRs, Mitsumi CD-ROM driver, mscdex, ansi, smartdrv, share, doskey, dpms, etc.
For what I use it for that seems to be plenty but I can pretty easily get it to 610K free by disabling the remote control TSRs, and probably somewhat higher by adjusting the files/stacks/buffers/etc settings in config.sys.
Reply 3 of 17, by NightShadowPT
Forgot to mention, but I am using Windows 98 DOS Mode (DOS 7.1 I believe)
Not sure why, but Memmaker does not seem to be very effective with my configuration...
Here is what memory looks like after Memmaker:
Modules using memory below 1 MB:
Name Total Conventional Upper Memory
SYSTEM 25,680 (25K) 13,792 (13K) 11,888 (12K)
HIMEM 34,128 (33K) 34,128 (33K) 0 (0K)
EMM386 3,120 (3K) 3,120 (3K) 0 (0K)
DBLBUFF 2,976 (3K) 2,976 (3K) 0 (0K)
ASPICD 12,752 (12K) 12,752 (12K) 0 (0K)
SETVER 832 (1K) 832 (1K) 0 (0K)
DOSKEY 4,688 (5K) 4,688 (5K) 0 (0K)
MSCDEX 15,936 (16K) 15,936 (16K) 0 (0K)
CTMOUSE 3,104 (3K) 3,104 (3K) 0 (0K)
KEYB 6,944 (7K) 6,944 (7K) 0 (0K)
ASPI7DOS 25,536 (25K) 0 (0K) 25,536 (25K)
DISPLAY 8,336 (8K) 0 (0K) 8,336 (8K)
IFSHLP 2,864 (3K) 0 (0K) 2,864 (3K)
COMMAND 10,064 (10K) 0 (0K) 10,064 (10K)
Free 591,104 (577K) 556,768 (544K) 34,336 (34K)
Memory Summary:
Type of Memory Total Used Free
Conventional 655,360 98,592 556,768
Upper 93,024 58,688 34,336
Reserved 131,072 131,072 0
Extended (XMS)* 36,869,280 562,336 36,306,944
Total memory 37,748,736 850,688 36,898,048
Total under 1 MB 748,384 157,280 591,104
Total Expanded (EMS) 33,947,648 (32M)
Free Expanded (EMS)* 33,521,664 (32M)
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 555,968 (543K)
Largest free upper memory block 32,752 (32K)
MS-DOS is resident in the high memory area.
I don't really understand why the rest of the programs are not being loaded into high memory, as they do have the Device High and LoadHigh tags... so I'm trying to find leaner drivers to see if it helps.
I can use QEMM and it will be able to push everything into high memory, but I want to also have a configuration with Himem and EMM386 for compatibility purposes.
NightShadowPT
Reply 4 of 17, by Disruptor
Loading EMM386.EXE with NOEMS option (instead of RAM) will add 64 more kB UMB space. This should fix your problem.
If you need EMS, try menus in CONFIG.SYS
If you use disks > 8 GB, you may need this patched ASPI7DOS driver:
INT13 Extensions to Adaptec 274x EISA & 284x VLB
Reply 6 of 17, by NightShadowPT
Disruptor wrote on 2022-11-11, 13:28:
My discs are under 8GB at the time, but this is a good tip. Thanks
maxtherabbit wrote on 2022-11-11, 15:17:
why the hell is HIMEM taking up 33kB??
That's what I would like to know 😁 ... I'm using the standard Himem.sys that comes with WIn98SE...
Just by changing the order in which the programs are loaded in autoexec.bat (and removing the useless specific memory sections added by memmaker) I have been able to move most of the programs to upper memory, and am now @587KB of conventional memory.
That is decent, if not great, but I am still puzzled about the 33Kb used by Himem.sys, as it seems too much.
How much is Himem.sys occupying in your configurations?
NightShadowPT
Reply 7 of 17, by darry
NightShadowPT wrote on 2022-11-11, 16:24:
My discs are under 8GB at the time, but this is a good tip. Thanks […]
Does your config.sys start with dos=high,umb ?
Mind sharing your config.sys and autoexe.bat ?
Reply 8 of 17, by NightShadowPT
darry wrote on 2022-11-11, 16:35:
Not at all, here they are:
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS /EISA /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM HIGHSCAN I=B000-B7FF X=DC00-DFFF X=C700-C7FF
DOS=HIGH,UMB
BUFFERS=12,0
FILES=30
LASTDRIVE=Z
FCBS=16,0
DEVICEHIGH /L:2,41552 =C:\DRIVERS\SCSI\ASPI7DOS.SYS /D
DEVICEHIGH /L:2,29632 =C:\DRIVERS\SCSI\ASPICD.SYS /D:ASPICD0
Country=044,850,C:\WINDOWS\COMMAND\country.sys
SHELL=C:\COMMAND.COM C:\ /P
DEVICEHIGH /L:2,16976 =C:\WINDOWS\SETVER.EXE
DEVICEHIGH /L:2,17184 =C:\WINDOWS\COMMAND\DISPLAY.SYS CON=(EGA,,1)
DEVICEHIGH /L:1,3712 =C:\WINDOWS\IFSHLP.SYS
AUTOEXEC.BAT
@Echo off
PATH C:\PROGRAMS\QEMM;C:\WINDOWS;C:\WINDOWS\COMMAND;C:\DOS;c:\tools\cc;c:\tools\pkzip;c:\tools\nc;c:\tools\maxdir
SET PROMPT=$P$G
SET TEMP=C:\TEMP
SET BLASTER=A220 I5 D3 H7 P330 E620 T6
LH /L:2,16016 doskey mcd=md $1$Tcd $1
LH c:\drivers\mouse\ctmouse.exe
mode con codepage prepare=((850) C:\WINDOWS\COMMAND\ega.cpi) >nul
mode con codepage select=850 >nul
lh keyb uk,,C:\WINDOWS\COMMAND\keyboard.sys
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:ASPICD0 /M:12 /L:F /E
SET CTCM=C:\drivers\SBAWE\CTCM
SET SOUND=C:\drivers\SBAWE
SET MIDI=SYNTH:1 MAP:E MODE:0
C:\drivers\SBAWE\CTCM\CTCM.EXE /Q
C:\drivers\SBAWE\DIAGNOSE /S >nul
C:\drivers\SBAWE\AWEUTIL /S >nul
C:\drivers\SBAWE\MIXERSET /P /Q
NightShadowPT
Reply 9 of 17, by NightShadowPT
And this is what the memory looks like NOW with the above configuration files:
SYSTEM 25,648 (25K) 13,760 (13K) 11,888 (12K)
ASPICD 12,784 (12K) 0 (0K) 12,784 (12K)
SETVER 864 (1K) 0 (0K) 864 (1K)
DOSKEY 4,688 (5K) 0 (0K) 4,688 (5K)
CTMOUSE 3,104 (3K) 0 (0K) 3,104 (3K)
KEYB 6,944 (7K) 0 (0K) 6,944 (7K)
MSCDEX 15,936 (16K) 0 (0K) 15,936 (16K)
Free 623,792 (609K) 601,024 (587K) 22,768 (22K)
Memory Summary:
Conventional 655,360 54,336 601,024
Upper 125,776 103,008 22,768
Extended (XMS)* 36,836,528 562,352 36,274,176
Total memory 37,748,736 850,768 36,897,968
Total under 1 MB 781,136 157,344 623,792
Largest executable program size 601,008 (587K)
Largest free upper memory block 9,920 (10K)
NightShadowPT
Reply 10 of 17, by maxtherabbit
This is PC-DOS 7
1.64 MiB
Reply 11 of 17, by NightShadowPT
Your Himem.sys is occupying only 1K? Wow...
Is that Himem compatible with MS-DOS 7.1?
NightShadowPT
Reply 12 of 17, by weedeewee
NightShadowPT wrote on 2022-11-11, 18:01:
Actually, the fact that yours is taking up 33k is highly suspect.
I just booted the win98 dos and its himem only takes up 1k.
and without loading dos high, it takes up just 4k of conventional memory.
Do not ask Why !
Reply 13 of 17, by davidrg
This is the memory usage of my 486DXf-100 if its of any interest - running DOS 6.22
Annotated Memory Usage
Name Total = Conventional + Upper Memory
MSDOS 19,021 (19K) 19,021 (19K) 0 (0K)
HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
DPMS 1,808 (2K) 1,808 (2K) 0 (0K) Needed by PHOST (otherwise PHOST uses a lot more memory)
IFSHLP 3,872 (4K) 3,872 (4K) 0 (0K)
COMMAND 3,184 (3K) 3,184 (3K) 0 (0K)
CTMOUSE 3,104 (3K) 3,104 (3K) 0 (0K) Mouse driver
PHOST 10,256 (10K) 10,256 (10K) 0 (0K) Remote control thing. Can't load high, supports windows, IPX only.
SETVER 512 (1K) 0 (0K) 512 (1K) Not sure why I've got this actually
VIBRA16 21,536 (21K) 0 (0K) 21,536 (21K) Creative garbage
CTMMSYS 8,112 (8K) 0 (0K) 8,112 (8K) Creative garbage. I assume I could drop one or both of these if needed
MTMCDAI 11,264 (11K) 0 (0K) 11,264 (11K) Mitsumi CD-ROM driver
ANSI 4,240 (4K) 0 (0K) 4,240 (4K)
SMARTDRV 29,024 (28K) 0 (0K) 29,024 (28K)
DOSKEY 4,144 (4K) 0 (0K) 4,144 (4K)
MSCDEX 27,952 (27K) 0 (0K) 27,952 (27K)
SHARE 13,888 (14K) 0 (0K) 13,888 (14K) Needed by C++ or pascal compiler IIRC. Could go if needed.
Client32 3,504 (3K) 0 (0K) 3,504 (3K) Whole network stack (NIC driver, IPX, TCP/IP, DHCP client & network drives)
TINYH_N 34,144 (33K) 0 (0K) 34,144 (33K) Different remote control thing - supports TCP but not windows
Free 609,840 (596K) 609,520 (595K) 320 (0K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 655,360 45,840 609,520
Upper 158,640 158,320 320
Reserved 393,216 393,216 0
Extended (XMS) 32,347,216 8,916,048 23,431,168 Most of the XMS usage is the network stack - cache is currently set to 4MB.
Total memory 33,554,432 9,513,424 24,041,008
Total under 1 MB 814,000 204,160 609,840
Largest executable program size 608,880 (595K)
Largest free upper memory block 192 (0K)
Are you sure that /EISA switch should be on himem.sys? Are you running this on a machine with EISA slots?
Reply 14 of 17, by Disruptor
I thought it is well known that there has been a buggy version of HIMEM.SYS in a Windows 95 or 98 release that consumes too much conventional memory.
Try another HIMEM.SYS please.
Reply 15 of 17, by NightShadowPT
davidrg wrote on 2022-11-11, 20:44:
Yes, my sistem is EISA (It's a Compaq Deskpro 486/66M).
Disruptor wrote on 2022-11-11, 20:57:
That seems to be the problem.
Just tried another HIMEM.SYS from a Windows 95 boot disk and now Himem is taking only 1K... Super!
Total free conventional memory is now 619K!
It's always funny to see how I started with a problem statement that ended up not being the solution at all 😁
Thanks everyone for the support
NightShadowPT
Reply 16 of 17, by doshea
NightShadowPT wrote on 2022-11-10, 20:45:
As many of you I am going through the struggle of getting the most out of my MS-DOS memory, but due to a SCSI Controller (Adapte […]
In terms of alternatives:
- For ASPI7DOS.SYS, perhaps if you look around you can find an older or newer version of that driver from Adaptec that happens to use less RAM, but I think it's probably unlikely you'll be able to find anything useful. I'm not aware of any third-party drivers you can use instead because this driver needs to support your specific SCSI controller.
- For ASPICD.SYS, you can probably use a different driver because this should be talking to ASPI7DOS.SYS via a standard ASPI interface. Most DOS SCSI drivers will come with such a driver, for example here are some other filenames which might help you find alternatives, although I don't have any idea about their memory consumption: AMD PCscsi: amsicd.sys; Symbios/LSI/NCR: symcd.sys; Tekram: trmcd.sys.
Reply 17 of 17, by zapedge
Hey just had the same and tested a few scsi cdrom drivers.
My card is a AHA-1542B PNP
Adaptec ASPI 4.01 aspicd.sys 12736 Bytes
Dawicontrol DC226U Ver 1.50 aspicd.exe 10736Bytes
BusLogic 3.30C btcdrom.sys 17360Bytes
Dawicontrol DC3X5U Ver 1.92 trmcd.sys 17152Bytes
Several others did not detect my drive.
So the aspicd.exe needs 2KB less than the official driver and on top of that my CD-Drive is not recognised and it sets it as an generic sony drive.
