First post, by vico
I built a retro PC mainly to play DOS games and some Windows 98 games.
Some specs:
Motherboard: Soyo SY-6VBA133
Processor: Pentium II - 300MHz
Ram: 512MB (Although only half is recognized)
Video card: NVIDIA RIVA TNT2 M64
Sound Card: CT4741 / Sound Blaster 16 / PnP
OS: Windows 98SE
Now, according to https://technical.city/en/video/Riva-TNT2-M64 my video card supports up to DirectX6.
However, there are some emulators that need higher Directx, for example Nestopia 1.40 needs Directx9.
Is there something wrong with installing a DirectX higher than the one supported by my video card?
Reply 1 of 5, by DEAT
No, you'll be fine - it's important to make the distinction towards DirectX and Direct3D. The TNT2 supports Direct3D 6 features, and those features still exist in the DirectX 9 runtime. There's games that require DirectX 9 but will run on a 2D-only card.
win16.page | Twitch
Reply 2 of 5, by vico
DEAT wrote on 2024-04-12, 00:00:
I understand. Thanks for the clarification.
Reply 3 of 5, by Minutemanqvs
The problems you might run into would be related to SSE if you encounter strange execution errors. Some later DirectX and drivers rely in it being present, but this was introduced with the Pentium III. So try to stay with versions that are "period correct" to your Windows 98 SE install and graphic card if you can just to be on the safer side.
Searching anything Nexgen, PM me if you have one. Also ATI Rage 128 PCI cards.
Reply 4 of 5, by eddman
Minutemanqvs wrote on 2024-04-19, 18:28:
I'm yet to see a DX dll have its requirements change. Things like d3dim.dll, etc. shouldn't require newer hardware.
Reply 5 of 5, by marxveix
I use up to 08 Dec 2006 - DirectX 9.0c if needed as i remember with AMD K6, zero SSE support there or maybe it was older DX9.0c. http://falconfly.3dfx.pl/directx.htm
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
