First post, by Grzyb
Guess what I just discovered...
CheckIt 3.0 and CheckIt 3.0 are not equal!
There are (at least) two variants...
- older, with CHECKIT.EXE of 351232 Bytes, and date Nov 6 1990
- newer, with CHECKIT.EXE of 333830 Bytes, and date Apr 10 1991
And the older variant seems better...
On my test machine, the older works without problems, while the newer consistently hangs on the "Interrupts" screen.
I'm getting paranoid...
Edit:
Closer examination reveals the following strings in .EXE files:
CheckIt 3.00i, 09/07/90
CheckIt 3.03C, 04/08/91
apparently never displayed, officially they are both just "CheckIt 3.0"... argh!
Reply 1 of 7, by Grzyb
There is one thing where the newer version is better: correctly recognizes >16 MB of memory.
Still only allows to test 16 MB, though.
And can't forgive the hanging "Interrupts".
Overall, 3.00i still seems the most reliable.
7.79 KiB
7.83 KiB
Reply 2 of 7, by analog_programmer
Ok, I just checked my version of CheckIt 3.0 and in CHECKIT.EXE I found this string: "CheckIt 3.01k, 01/30/91". The executable itself is 330709 bytes. So we have more than two versions of CheckIt 3.0 😁
P.S. CHECKIT.OVL also varies in size between the different CheckIt 3.o versions.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 3 of 7, by Grzyb
analog_programmer wrote on 2024-05-06, 08:27:
Yes, larger CHECKIT.EXE = smaller CHECKIT.OVL
Obviously they moved some code between those files.
Reply 4 of 7, by analog_programmer
Grzyb wrote on 2024-05-06, 09:31:
Correct.
But there is also another difference unrelated to executable files: help file varies in size too 😀
Reply 5 of 7, by Grzyb
analog_programmer wrote on 2024-05-06, 10:55:
You mean CHECKIT.HLP, right?
Strange, it's exactly the same in 3.00i and 3.03C...
perhaps your version isn't in English?
Reply 6 of 7, by analog_programmer
Grzyb wrote on 2024-05-06, 11:02:
Yes, I mean CHECKIT.HLP and my version of Checkit 3 is in English too, but as I mentioned, a different revision 3.01k. Of course, the help file has no impact on the stability of the software.
P.S. Ok, I compare my files to some 3.00i versions circulating on the web. I can't find version 3.03c for comparison.
