Windows 10 on Core2Duo
First post, by AlessandroB
They gave me a Pentium4 and the motherboard is an Asus P5LD2-SE, looking for information on this card I discovered that it can mount up to the Core2Duo E6700. Unfortunately my revision is 1.0 so I can't mount it. But it reminded me of a possible support computer for retrocomputers. Since this card (in the C2D compatible version) has the IDE channel, the Floppy drive, the SATA as standard, it could be an excellent laboratory computer for creating Floppy disks, testing IDE drives etc. The only doubt is whether Windows 10 works with a C2D E6700 and whether it works at least decently to be able to navigate, download software, burn CDs... or whether the CPU is too slow. I'm currently using an AMD A4-5300 which unfortunately doesn't have floppy or IDE support so it's very limited. Plus this AMD is quite slow to run Win10, would the E6700 be better or at least the same? If it were slower it would be useless. What if instead of installing win10 on the E6700, I installed Windows7? Is it still decently supported at browser level?
Reply 1 of 15, by chrismeyer6
I had windows 10 installed on my old core 2 E8600 system with 8 gigs of ddr2 1066 and honestly it ran just fine. It wasn't a speed demon or anything but with a SSD it was snappy enough.
Reply 2 of 15, by AlessandroB
But this board support max a E6700 and 4Gb of memory
Reply 3 of 15, by chrismeyer6
It'll still run. My wife's older laptop was similar CPU and 4 gigs of RAM. It served her needs fine untill the battery failed
Reply 4 of 15, by AlessandroB
chrismeyer6 wrote on 2024-05-17, 19:07:
interesting thanks.. and what about the use of Windows7 in this scenario? about browser availability ecc
Reply 5 of 15, by DosFreak
If we are just talking about Windows then:
Windows 10 will likely be more memory efficient than 7 but it'll all be gobbled up by the browser so make sure you use pihole,noscript/ublock origin, etc.
You may want to compare 10 32bit vs 64bit as far as memory usage.
There are stripped down versions of Windows 10 out there if you don't want to do so yourself but those can't be mentioned here.
Make your games work offline
Reply 6 of 15, by jmarsh
It takes a bit of effort to find an up-to-date browser supporting windows 7.
It's a shame because windows 10's memory usage is bloated and it doesn't really run acceptably with only 4GB, which rules out using windows on machines that are still fairly usable but have a fixed amount of RAM e.g. laptops, compute sticks...
Reply 7 of 15, by Cyberdyne
The main hurdle is Windows 10 loading time on mechanical harddrives. 🫤 Else even first gen Core2Duo is just fine for 10 and even hacked 11.
Reply 8 of 15, by AlessandroB
So would a card like the Asus P5L2D be good as a support computer, internet consultation, CD burning, etc? and would the Floppy disk and IDE channels of this card (which has the 945 chipset) work well on win10 even though technically I don't think it has the drivers for these components?
Reply 9 of 15, by AlessandroB
so i move to hardware section to find a proper MB.. thanks for now
Reply 10 of 15, by theelf
jmarsh wrote on 2024-05-17, 19:51:
hee... no, you have Supermium, and is in Release Announcements forum
https://github.com/win32ss/supermium
I dont like 10, in fact hate vista+ NTs, but 10 work fine in a laptop i have with 2GB, just not use official releases, use for example tiny10
Reply 11 of 15, by Cyberdyne
Firefox LTS it even has 32bit version.
Reply 12 of 15, by ODwilly
Windows 10 32bit with a 2.0ghz dual core P6100? 4gb of ram and a 250gb SSD isn't really bad. In my experience there was usually 200mb roughly of memory free. As long as you stuck to 2-3 tabs in Firefox.
Reply 13 of 15, by swaaye
I haven't seen any problems with Core 2 and Win10. 4GB is a bit tight but it's adequate for web, email, and a basic office suite. You want an SSD though and a discrete GPU with Win10 drivers, so you aren't sharing system RAM and you aren't on video drivers meant for Vista as the IGP would be.
Reply 14 of 15, by AlessandroB
swaaye wrote on 2024-05-19, 04:16:
and an Athlon II X2 250 can be right for Win10??
Reply 15 of 15, by chrismeyer6
That should be fine for windows 10 it's a similar era as Core 2
