Seriusly windows?
First post, by Nic-93
Would i really need a start disk image and then get it to run or cant i change it up so the wdinws 98 system starts automatic?
Its after i had installed dos 6.x.
Reply 1 of 7, by derSammler
It's apparently not booting MS-DOS 7.1, but 6.x. You can not start Win 9x on MS-DOS 6.x. Start from the setup disk once and do a "sys a: c:" at the command prompt. After that, the problem should be gone.
Reply 2 of 7, by Jorpho
Nic-93 wrote:
i had installed ms-dos 6 first with cd rom driver's and sound blaster live in windows 98, then when i restarted it did that error.
This sentence is entirely unclear. But if you are mixing MS-DOS files and Windows files, then this is the sort of thing you can expect.
I agree that "sys a: c:" should fix the problem.
Reply 3 of 7, by Nic-93
You mean the windows 98 boot disk and it should be good?
Supose to make situation easy is to format the drive and use the windows disk.
Reply 4 of 7, by Jorpho
Yes, the Windows 98 boot disk.
That is one option, but "sys a: c:" only takes a second and will fix the problem just as completely.
Reply 5 of 7, by Nic-93
ah, sorry, that does sound easy, is it like a command the sys a: c. thing is?
i havent done that alternate before.
Reply 6 of 7, by yawetaG
"sys a: c:" (note correct punctuation) is a command that will copy the MS-DOS start-up files from the Windows 98 boot disk to your hard disk.
Reply 7 of 7, by Nic-93
well, that was easy, yeah.
