First post, by bluejeans
Having trouble finding one to run on 9x. It would be infinitely more easy to use to share files than networking and sharing, I have enough trouble doing that between computers that are both 7. I really would prefer a gui. Most 9x ftp programs I've seen don't have a win 7 version, either.
Reply 3 of 19, by bluejeans
Baoran wrote:
Cuteftp used to be my favourite ftp client back in the win98 days. http://www.oldapps.com/CuteFTP.php?system=Windows_98
Perhaps this thread should be in the software forum instead of hardware?
Oops. I only ever post about hardware so forgot there was another section.
Reply 4 of 19, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 5 of 19, by leileilol
There's an older Filezilla that should be usable.
If you're wanting silly period correctness, WS_FTP is the way to go 😀 Bulletproof FTP and SmartFTP were also popular.
Reply 7 of 19, by Zup
LeechFTP as client, 3COM FTP server as server. Both should work fine on Windows 95 (maybe you'll need Winsocks update) and are easy to configure.
There can be security issues, but the entire Windows 95 is a security issue.
I'm selling some stuff!
Reply 8 of 19, by kaputnik
Used SlimFTPd back in the day. It's simple, stable, and has a very small memory footprint. Also, it doesn't write anything to the registry. You'll have to live with manual configuration through a .ini file though, there's no GUI.
As for the client, Total Commander's built in one has been good enough for me through the years.
Reply 9 of 19, by Joey_sw
i using Total Commander (previously known as Windows Commander) for its FTP feature.
-fffuuu
Reply 10 of 19, by Jorpho
Or you could just direct whatever browser you're using to the ftp:// URL. For a server I use smallftpd on my Win 7 machine when I need it.
Alternatively, Bluetooth file transfers are astonishingly straightforward, and Bluetooth adapters are quite cheap.
Reply 11 of 19, by Ampera
Use SMB, it's been in windows since 3.11 I think.
Reply 12 of 19, by Jo22
At school we used Ipswitch a long time ago.
Reply 13 of 19, by leileilol
In between the various Windows you can't expect SMB to work consistently, especially with the latter Windows' security-related changes that regress access to SMB'ing other Windows.
When I needed to SMB access a W98 PC from W7, I had to VirtualPC a W98 guest to do this easily.
Reply 14 of 19, by PhilsComputerLab
I found FTP way too clunky and slow to use. I have no problems accessing Windows shares on Windows 10 from 98 SE machines. There is a tutorial on my channel if anyone is interested.
YouTube, Facebook, Website
Reply 15 of 19, by Azarien
I remember I had a problem with SMB sharing between Windows 7 and 98, but not between the same Windows 7 and 3.11.
Go figure...
Reply 16 of 19, by Errius
IIRC you can access W98 shares from W7 but you can't access W7 shares from W98.
I was never able to get SMB working between W7 and W95.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 17 of 19, by appiah4
LeechFTP as client. On the server side there are a lot of options, depends on your hardware really.
Reply 18 of 19, by oeuvre
FileZilla 2.2.18
Reply 19 of 19, by appiah4
oeuvre wrote:
FileZilla 2.2.18
I refrained from suggesting this because it doesn't work too well with lower Pentiums and below.. But if you have an MMX or higher, yes it's a good option. LeechFTP is usually lighter on resources but gets the job done nonetheless.
