First post, by smevans526
Surprisingly, talk on wolf3d with the gravis pad is minimal. I'm talking about the original white 4button pad and have it plugged into an awe32.
When I try to setup it up, I cannot immediately select USE GRAVIS GAMEPAD. I have to select USE JOYSTICK first, which calibrates it as two buttons. I can then select the gravis option, but not all 4 buttons are accessible. It uses two for shoot and strafe, and the other two the same. I want to calibrate the pad with wolf3d acknowledging all 4 buttons.
Any advice on how to do this?
