First post, by buckeye
In Moto Racer 2 I can make thru the settings/setup race screens but when an actual race starts loading:
In D3D the "load meter" goes all the way but then the game quits back to windows.
In Glide the "load meter" will go part of the way then it freezes - I hit spacebar and it goes back to windows.
Specs: P3 850 512mb GF3 V2 SLI Vortex 2 Dx8/Nvidia drivers 23.11/latest ref. 3dfx drivers. Game is patched to version 1.35 (only patch I could fine & it's on the game disk)
Figured this game would run like dream but boy was I wrong. Anybody know where I might be screwing things up?
Reply 1 of 3, by KCompRoom2000
What version are your Aureal Vortex 2 drivers? Since you've mentioned DirectX 8 in your specs, chances are your Aureal drivers are causing problems. Aureal drivers 4.06.2015 are recommended for DirectX versions 7.1 or newer, the use of newer driver versions (most notably 2041 and 2048) with DirectX 7.1+ is known to cause games to lockup/crash, so it may be worth a shot to try different Aureal drivers.
Reply 2 of 3, by buckeye
Finally!!! Thanks for responding, this game is driving me nuts. I'm using the drivers that came with the install CD so like you say, may need to bump them up.
I'll update them and post the results, hopefully this will clear up the issue. Tried the game on XP but it didn't work on that either.
Reply 3 of 3, by buckeye
An update on this: Replaced the Vortex2 drivers with version 4.06.2041 but still no go. So using the -h switch on the command line which brings up the different options I noticed there was an -NoCpuDetect switch so tried that and it runs! But only in D3D with the GF3, still crashes in glide. Will continue to play around with the different switches and see what i can come up with so it will run with my V2's.
