Recent WinXP/POS2009 update causes errors with PIII systems
Getting old software/games running on older hardware.
Re: Recent WinXP/POS2009 update causes errors with PIII systems
Postby DosFreak » 2018-11-08 @ 14:36
https://msfn.org/board/topic/171814-pos ... nt-1156093
11-7-2018
Ok I went for it - everything up to present with the following excluded:
KB4340937
KB4343674
KB4458000
KB4462987
KB4034775
KB4458006
KB4042007
KB4050795
KB4093257
KB4463573
KB4074852
KB4134651 (both versions offered)
Seems like I'm good, everything's working!
https://msfn.org/board/topic/177915-bew ... 0-updates/
Looks like KB4461522 for Office 2010 is incompatible with Windows XP. Likely not compiled for XP on the newer VS but only Vista+
This is good info especially for those of us who use emulators like pcem and want to test software which no one seems to do anymore.
User avatar
DosFreak
Postby feipoa » 2018-11-08 @ 20:00
DosFreak wrote:...and want to test software which no one seems to do anymore.
LOL! The consumer acts as the QA analyst these days, it is horrific.
User avatar
feipoa
Postby gerwin » 2018-11-08 @ 22:20
Yes and no. Since when you find a flaw and report it to Microsoft they don't do anything with it. I am thinking of Skype bricking XP or Posready systems, how long ago was that? 2015 it was.
That MSFN thread (which is huge by now) is a great resource. I check it like every few months.
The other day there was a SSD tool mentioned there. Here is a free warning from my own experience: Manual TRIM can cause extensive loss of user data. At least with Crucial SSDs and Windows Posready.
User avatar
gerwin
Postby feipoa » 2018-11-12 @ 03:27
Is there a similar list of omitted KB updates for Windows 7 Pro on SSE1 CPUs? And do the Win7 updates incorrectly try to install on SSE1 CPUs causing errors, as it did with POS2009? Or is the updater smart enough to check for SSE1 first?
I'm in the slow process of setting up an ultimate dual Tualatin SCSI RAID testbed with 4 OSes in multi-boot. As there is a 4 primary partition limit, I was thinking of NT4/W2K/XP/Win7 or NT4/W2K/XP/W2k3. I previously tried this using logical drives in extended partitions for greater than 4 partitions, but the Win7 installation messed up itself and the boot loader. Rather than find a solution to this, my brain says just to use 4 OSes instead of 5. I suppose I could also drop NT4 and have W2k3 and Win7.
User avatar
feipoa
Postby nd22 » 2018-11-14 @ 15:32
I installed tonight the November updates and I can report that all of them are working fine!
4466388: OK
4467689: OK
4470118: OK
4470198: OK
The internet explorer update always installs on any system regardless of the presence of SSE2 instructions set or no!
The system is very responsive - in fact i am playing Doom 3 right now b :blush:
nd22
Postby nd22 » 2018-12-24 @ 18:39
After a long hiatus due to work I installed tonight all the December updates and I can report that all of them are working fine except one:
4468323: OK
4473077: FAILED
4473078: OK
4470633: OK
4470490: OK
4467770: OK
Also the extra update for internet explorer kb4483187 released on December 19 installed OK!
The system is not performing any slower than before so we will be fine :blush:
nd22
Postby nd22 » 2019-1-12 @ 12:22
Today I installed all the updates from January and I can report that everything is running fine :happy:
These are:
4480965: OK
4461635: OK
4481275: OK
4480087: OK
4480077: OK
We are now on the last 3 months of support left!
nd22
Postby feipoa » 2019-1-12 @ 12:27
Have any special plans thereafter?
User avatar
feipoa
Postby nd22 » 2019-1-12 @ 15:24
I plan to backup the entire hard drive - only 80 GB - to one of the larger ones and just keep using the system. I am using a software antivirus - Symantec endpoint protection - that is pretty good in my opinion; also I am using a router, the system is not connected directly to the internet. In the end I think the main weak point is between the chair and the monitor :lol: ; the user should browse the web responsibly!
nd22
Postby awgamer » 2019-1-12 @ 15:51
I find it interesting that the year the patent for SSE expires(you can now build your own Pentium IIIs,) latest patches now require SSE2. Based on this patches in 2021 will require SSE3.
awgamer
Postby DosFreak » 2019-1-12 @ 22:14
It's not a conspiracy, just different teams at MS using different compilers and/or compiler options.
User avatar
DosFreak
Postby feipoa » 2019-1-13 @ 11:51
DosFreak wrote:It's not a conspiracy...
I don't know what to believe anymore - I believe all of it, at the same time, I believe none of it. There is very little I can say with certaintiy that is based upon first-hand knowledge.
User avatar
feipoa
Postby dr_st » 2019-1-13 @ 12:17
awgamer wrote:I find it interesting that the year the patent for SSE expires(you can now build your own Pentium IIIs,) latest patches now require SSE2.
So that's what the long line of people outside the TSMC fab was? People eager to build their own Pentium III?
User avatar
dr_st
Postby awgamer » 2019-1-13 @ 15:49
Sarcasm? Companies wanting to build x86 chips is a thing: https://www.bit-tech.net/news/tech/cpus ... x86-cpu/1/ but don't from lack of license, which Intel doesn't hand out. As patents expire, that restriction goes away, but is only valuable if the patent free instructions are current enough to still run things, Intel method to keep a lock on x86 is to regularly come out with new instruction sets, deprecating the old helps to that end as well. Microsoft does things in similar fashion with compelled deprecation of drivers for older Windows. On par with standard operating procedure. sse starting to be patent free is a meaty one compared to mmx before it. Past eight years performance improvement has crawled while patents keep expiring so it's heading to a convergence point with anyone able to make current enough and fast enough x86 chips on their own that will run most everything, like say xyz companies in china, new and deprecated instruction sets keeps ahead of that.
ps. Here are games that are blocked by denuvo DRM from running on older systems from requiring SSE 4.1/4.2.
https://linustechtips.com/main/topic/95 ... tructions/
https://forums.ubi.com/showthread.php/1 ... rums/page3
and along the same lines, pin testing shows how intel new socket not necessary, except force upgrading/spending money.
https://www.youtube.com/watch?v=cMY-EEFkGVk
awgamer
Postby dr_st » 2019-1-13 @ 17:09
You got a point.
Building just a Pentium III would be pretty useless, but if one could build a fast x86, without the "patented" instructions, that can still compete with Intel's latest offerings, it could be a thing.
Still, I believe you must be wrong somewhere, because if someone could build such a competitor, without the patented instructions, but software would not run on it because of same instructions, a very strong case of vendor lock-in could be made and the anti-trust bodies would make minced meat out of... someone. Why isn't it happening?
User avatar
dr_st
Postby awgamer » 2019-1-13 @ 17:39
That's not the situation, newer software is requiring newer still patented instruction sets. sse4.2 are sse instructions but are different from sse 1.0, and still patented.
awgamer
Previous
Return to Software
Who is online
