First post, by foil_fresh
Hi, I'm interested in seeing what cool file managers for dos you all use?
I'm using dosshell from dos 6x but unfortunately I have so many games and game files that it takes roughly 2 minutes to load dosshell - a pain in the macadamias each time I reboot.
Are there any file exploreres that might do some indexing or possibly only read the content list of the folders when I try to view them?
I tried xtree gold but that didn't even work as it sprung an error (probably too many files).
I have a dos game launcher someone but it's cumbersome to create separate entries for 600+ games. It's cool but i gave up after configuring the 20th game.
Thanks
Reply 3 of 20, by Cyberdyne
Volkov Commander 4.05 has never caused me any trouble, and is fully written in assembly. So small and fast.
Reply 4 of 20, by jheronimus
I'm using Norton Commander too. It was absolutely ubiquitous in Russia and CIS countries in the 90s, so that's what I grew up with. It's really feature-packed and can even work with archived files (at least with zip archives). Really solid choice and this is what I use on all of my DOS machines to this day.
Volkov Commander was pretty popular, too. It was often used on boot floppies and warez CDs because it is really light. I've never used it extensively, though, so I'm not sure about the functionality.
MR BIOS catalog
Unicore catalog
Reply 8 of 20, by root42
DOS Controller (dc.com) by Soren Kragh. Freeware, can be found by googling a bit. Extremely small, written in Assembler, faster than Norton Commander, less memory footprint. Does most of the stuff and has same user interface.
YouTube and Bonus
Reply 9 of 20, by rasz_pl
Limitations:
Doesn't list some CD-ROM or RAM disks (XMSDSK).
Can't copy directories.
umm, wow
Reply 10 of 20, by konc
Just for the sake of the discussion, I did try this one and it is indeed very small and fast. But it's missing a very important feature which was a deal breaker for me: copying whole directories.
edit: rasz_pl beat me to that
Reply 11 of 20, by root42
True, the recursive copy feature is a bummer. However I managed to work around it. Under DOS you tend to have not very nested directory structures.
CD-ROM support is currently no problem for me, since my 386 doesn't have one. 😉
So dc.com is probably best for very old PCs, working off floppies and/or with limited RAM and CPU.
YouTube and Bonus
Reply 12 of 20, by cyclone3d
@ foil_fresh
1. Are you using Smartdrive ? That should speed up the loading of Dosshell quite a bit.
2. What kind of drive are you using? If a regular HDD, you can gain a whole lot of speed by changing to a fast CF card or SSD. Access times are the big factor here.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 13 of 20, by GigAHerZ
Doesn't really matter with norton commander, as it is able to almost completely unload itself before executing any program...
Reply 14 of 20, by keropi
There are some people what work on a project called ReDOS: http://www.orbitalcrew.com/redos.html# , https://www.facebook.com/F.H.OrbitalCrew
They uploaded a boot video on facebook, I have no idea how to get a link to share but here are some shots of it, kinda looks like workbench . They said it runs all DOS software , maybe based on freedos? looks interesting.
Reply 15 of 20, by foil_fresh
wow, thanks for all the reccomendations. Norton commander seems promising.
cyclone3d wrote:
@ foil_fresh
No smartdrive (or at least I don't think so), i'll check that out. I'm using dos 7 from Win98se - is smartdrv a feature in w98?
When I wrote this post I was using CF, but my SD adapter came in the mail yesterday and reinstalling onto that tonight. it should speed things up a tiny tad.
Reply 16 of 20, by Caluser2000
I used Quickmenu III by Neosoft to orginise my old dos system. It has a file manager built and a lot of other useful utilities in it as well. Fits on a 720k floppy disk and can be used on XT class systems. To use backgrounds you'll need EMS. You can create submenus as well.Uses mouse and/or keyboard shortcuts.
57.39 KiB
"Quikmenu 3 is a fully graphical, icon based Dos menu. It allows you to easily create a menu for all your Dos programs and games with icons, marcos, and even phone connections! It comes with several internal utilities including a calculator, calendar, phone book, and a time log to keep track of what programs you use. It also has a easy to use, yet powerful file manager utility. Finally, you could also use Quikmenu on a network and send E-Mail right through its built in mailer!"
Disk(Unregistered) just a nag screen iirc
QuikMenu_III.zip
511.77 KiB
100 downloads
Extra Icons
QuikMenu_III_Weeds_Icons_Library.zip
203.09 KiB
74 downloads
Reply 17 of 20, by BinaryDemon
I used to rock Quikmenu3, great GUI for DOS.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 18 of 20, by Caluser2000
Looks like NeoSoft is passing on it's software development to an outfit in Spain. Use to have links to their old Dos stuff as well on the website but unfortunately not anymore. I got NeoPaint off them as well back in the day. That and QM3 ran really well on a 286/16 with 4megs of ram.
Reply 19 of 20, by foil_fresh
Caluser2000 wrote:
I used Quickmenu III by Neosoft to orginise my old dos system. It has a file manager built and a lot of other useful utilities i […]
QuikMenu_III.zip
Extra Icons
nice! i will try this one out for sure.
