Retro OSes for retro computers
Getting old software/games running on older hardware.
Re: Retro OSes for retro computers
Postby ArtiomWin » 2019-6-11 @ 12:36
Cyberdyne wrote:No not commercial UNIX, just Linux distros, because there are so many, and they are basically the same, and you can even make a minimal distro today, it does not really scream a certain period of time. It is allmost the same, if you call FreeDOS a retro operating system. But i dislike pure FreeDOS for different reasons, i like that DOS is clean, on the point and, minimalistic, but Feedos is like Linux, it starts up and tells me too mutch. Long licensing texts and so on. Thank god that it does not ask me to log in. Some time ago i made a FreeDOS distro just for my personal use, that mimics a classic DOS feel. But i abandoned that and still use industry standard MS-DOS 6.22 and 7.10. And tinker with DR-DOS.
I see your point. FreeDOS is touted as system that compatible with modern hardware and yet able to run legacy DOS software, however it's mostly unnecessary these days since PCem and its forks are matured enough you can install there most of legacy x86 systems. Few years ago you couldn't imagine these emulators would emulate MicroChannel architecture!
ArtiomWin
Postby appiah4 » 2019-6-11 @ 12:44
I don't share this sentiment, the modern Linux kernel has shed a lot of compatibility with older hardware from itself, and 90s Linux is nothing like modern Linux.
A500:Rev6|+512K|ACA500+|C1084S
i386:Am386SX25|4M|GD5402|ES688|MuntPi3
i486:U5S33|8M|GD5428|YMF719|DB-S2
i586:P133|32M|T64+/MX2|V1|CT3980/32M
i686:K6-2/400|128M|V2/SLI|CT4520/32M
S370:P3-1200|384M|GF4-4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby ArtiomWin » 2019-6-11 @ 20:41
appiah4 wrote:I don't share this sentiment, the modern Linux kernel has shed a lot of compatibility with older hardware from itself, and 90s Linux is nothing like modern Linux.
Maybe I just didn't get your opinion. Such difference may take place also between IBM OS/2 and its descendants like eComStation or ArcaOS.
ArtiomWin
Postby appiah4 » 2019-6-11 @ 21:08
Indeed.. Does that mean we shouldn't discuss OS/2?
User avatar
appiah4
Postby Caluser2000 » 2019-6-12 @ 02:39
appiah4 wrote:Nice.. Should we maybe have a seperate 'Best Linux Distros for Retro PCs' thread or just discuss that here?
Not a bad idea. Most modern stuff is way too bloated. Tried a more modern linux distro on my P1 166 with S3 Virge/DX video card, 32megs ram and it complained about not enough ram. Xandros2 from around 2002 ran just fine. Early distros of the 90s never had auto config routines like today, later ones did start doing that ie coral linux. Also each one has a different routines. Ones that work fine on my P1 testing set up so far are Xandros 2, Turbo Linux 6, earlier Red Hat. earlier Mandrake 6/7 and SuSE 7.2. I could even set up apt to some more archives to get more software. Of course you can compile but that takes ages. KDE 3 on Xandros is more bloated than Window Maker or Gnome 1.2. I use to run Red Hat 7.3 on a P200mmx system with 256megs of ram, 2meg vdeo card and that run fine in X once I got rid of all the Gnome stuff and Nautilus crap. I'd personally say a 2.2*-2.4* kernals are ideal for these systems for nostalgic an practical reasons. Most distros these days are for 686 or greater even 32 bit support is dropping on a few. So no they are not the same. Like NT 3.* and Windows 10 are not the same.
Wrt FreeDos you can get a floppy version. I use DCUs MSDos 7.1 that can be installed just off the first disk giving you an even leaner version compared to MS Dos 5 and 6* yet with fat32 support.
Of course we should consider the likes of older OS/2 and *nix variants.
User avatar
Caluser2000
Postby Caluser2000 » 2019-6-12 @ 04:58
ArtiomWin wrote:Just installed SCO Open Desktop to emulator. This system runs smoothly on Pentium 66 and 8 megs RAM. But installation is a very long process (more than 40 floppies!).
Here's how it look likes:
Thats pretty cool. Of course REAL hardware is the way to go :)
User avatar
Caluser2000
Postby appiah4 » 2019-6-12 @ 07:34
2.2-2.4 is indeed the best Kernel for pre-2000 stuff, I ran Slackware 3.something on 486/Pentium hardware circa 97-98 and Redhat 5.2-6.0 on Pentium II/III hardware circa 98-2000. This was the time I was having to let go of OS/2 and wanted an alternative - I just refused to move to Windows. I basically almost completely skipped Windows 95, ran a bit of Windows 98 and Windows won me over with Windows 2000..
I would really appreciate a thread to discuss older Linux distros and what distro works best for which hardware, I think..
User avatar
appiah4
Postby ArtiomWin » 2019-6-12 @ 21:01
Caluser2000 wrote:Thats pretty cool. Of course REAL hardware is the way to go :)
Well, I don't have lot of space for vintage hardware, but it's still interesting to look up at ancient software...
P.S. I'm also posting to unlock PM sending :blush:
ArtiomWin
Postby Caluser2000 » 2019-6-12 @ 22:12
Makes sense. In emulation you can try out all sorts of software from a variety of platforms. I'm just with a lot of space and time on his hands.
User avatar
Caluser2000
Postby ArtiomWin » 2019-6-14 @ 20:58
Hello. Today/tonight post refers to where the topic started.
Last year, QNX 2.xx finally made it's way to Internet Archive, and now I would like to post here screens of it. Yes, that's not demo disk, but full version!
(here's version 2.15G)
ArtiomWin
Postby lolo799 » 2019-6-16 @ 22:14
40 floppies, doing it in an emulator is obviously easier, doing it on a real machine is tedious...
Or "Best exotic OS for retro PCs" since many systems mentioned here are not so old actually...
I think we can use this thread for that, and yes, the "Retro OSes" is not completely accurate as there are still developed Oses that run on old computers, like the one I'll write about below.
You can make a minimal distro today, but saying old Linux distros don't scream a certain period of time is wrong, just check for exemple an old RedHat like the 5.x, or Suse 5.x, you'll see they differ a lot from recent installments.
For today, 3 floppy disks sized OS, 2 of them based on Linux.
-First one is a bootable root disk based on a 0.99 kernel, it comes as a 1.2MB and a 1.44MB image, the intro part of the readme says this:
Linux Bootable Root Disk [HJ release]
Introduction
This is a bootable root disk for Linux. The kernel is 0.99 patch level 7
with 387 emulation, minix fs, msdos fs (version 0.10 hacked for 0.99.7),
ext fs, ext2 fs, xia fs (with fix for 0.7.3), SCSI, CD-ROM and TCP/IP
support. There are some basic binaries on the root disk, all of which are
linked with the C library 4. There is a light version of the shared image
4.3.3, libc-lite.so.4.3.3, which doesn't have curses and gdbm. I don't
have an Ethernet card to check out TCP/IP. Please consult the NET channel
and modify /etc/*.
rootdisk099.zip
(1.31 MiB) Downloaded 6 times
Second one is a later version of cramdisk that I posted on the first page at viewtopic.php?f=61&t=61085#p690820
It's the 2.02 version from 1997, running the 2.0.26 kernel and requiring a 486 with 16MB of RAM, it comes on 2 superformatted floppy, the 2nd floppy containing a small X Windows system.
It uses superformatted floppies in an interesting way, here's an excerpt from the readme:
The "net.16MB" distribution makes use of the /dev/fd0H1920 driver
built into the recent Linux kernels to give 30% more capacity
than a standard 1.44 MB floppy. The first 19 sectors (it's probably meant to say tracks) of the
floppy (tracks 0-18) are formatted normally (18 sectors/track)
but the remainder (tracks 19-79) are formatted with 24
sectors/track.
cramdisk-2.0.part1.rar
(3 MiB) Downloaded 5 times
cramdisk-2.0.part2.rar
(2.28 MiB) Downloaded 5 times
Last one is a 16-bit real mode one man project currently being developed, written in assembler, it comes as a 1.44MB floppy, runs on as little as a 386 with 640KB, comes with a bunch of applications and games, the full source code is available and there's documentation as well:
Get it (or just take a look at the many screenshots) on its author's website:
http://sebastianmihai.com/snowdrop/
And if you don't have time to give it a try, he also made a video of it at https://youtu.be/ICEThAwd7Ik
lolo799
Postby Caluser2000 » 2019-6-21 @ 23:02
Basic Linux 3 is a small distro based on Slackware 4.0. It can be installed to an ext2 partition and you add extra packages if you want. http://distro.ibiblio.org/baslinux/ They have links to Slackware ftp reposatories.
User avatar
Caluser2000
Postby creepingnet » 2019-6-25 @ 23:21
Writing from my phone...large text? Just some thoughts so don't take it too seriously
That said, I see a lot of talk in this thread about doing fairly modern things with alternative OS on older PC hardware.
I've found the best platforms for that for me are still DOS and Windows because that's what everyone focused on.
A prospect as a Retrocomputing guy is the idea of maybe building a whole new O/S using what say...almost 40 years of knowledge and experience via the Internet that we have would be interesting.
A lot of what has been created as result of it's time period. Some were made to gain traction in the market, make PCs more accessable to non technical people, make newer PCs run at their full potential, connect to mainframe 10+ years old UNIX archetecture, make computing more accessable to the poor, make PCs more secure, split off from a competitor, or make up for past product mistakes with a whole new platform.
But now..the 8086, 286, 386, 486, Pentium, and a couple gens higher don't have these urgent roadblocks a new OS can solve. It's a 100% geek/nerd platform. Sally in HR no longer needs to be taught repeatedly that she can use DIR /W to find her files.
I really wish I could take up ASM and get good enough to create a solid bootloader, filesystem, and go from there. The sky is the the limit when you're not a multi-million dollar corporation trying to strangle the market, or trying to make a self-sensing borderline sentient AI pile of algorithms trying to make your computer as easy to use as your toaster.
My DOS Boxen
85' Tandy 1000(a)- 8088/4.77, 640K, 8gb XT-IDE, TGA, 3-voice
89' GEM 286 - 286/12 w/287, 6MB, 1GB SCSI, 2XCD-ROM, ET-4000 1MB, SB Pro2
Creeping Net 486 - 486DX4100 WB, 128MB, 512K L2, 15GB+40GB, S3 809 2MB VLB SVGA, SBAWE64
User avatar
creepingnet
Postby matze79 » 2019-7-09 @ 06:13
BonnyDOS/286
http://bonnydos.retro-net.de/
Shell:
Graphical Enviroment:
A Wordprocessor:
https://www.retroianer.de
matze79
Postby Caluser2000 » 2019-8-23 @ 23:53
This looks interesting https://forums.somethingawful.com/showt ... id=3889353
System requirements :
Minimum Hardware Requirements for Version 1.20
Because FAMOS will produce maximum performance from your computer, you will
find that even older computers will become useful again. So FAMOS has been
designed to work on 32-bit computers with modest specifications:
Processor (CPU): Pentium 1 and above
Coprocessor: 80487 and above
Memory (RAM): 512 Mb or more
Video card: VESA VBE2.0 or better
Video RAM: 1Mb minimum
User avatar
Caluser2000
Postby hwh » 2019-8-27 @ 08:54
I don't think I could bring myself to run something that refers to "apps."
hwh
Postby Caluser2000 » 2019-8-28 @ 09:11
Just too prove Nescape Communicater 4.72 can post here on an old system. I'm posting on Turbo Linux 6.0 which came out in 1999 and uses the Gnome 1.x desktop.
It's actually quicker than running Palemoon on Windows 10.
System specs are Pentium 166MMX, 32megs of ram, SIS video card with 8megs vram attached to a16.5" Transonic LCD TV with brand new panel fitted, Screen res 1024 x 768. Realtech RTL8139D based Nic and 4 gig BigFoot hdd
User avatar
Caluser2000
Postby lolo799 » 2019-9-01 @ 11:51
hwh wrote:I don't think I could bring myself to run something that refers to "apps."
That' a bit nitpicking, no? Wasn't Lotus 1-2-3 described as a killer app in its time?
Using "apps" instead of "applications" saves a little bit of storage space on a floppy, it may be not necessary but it can be useful.
matze79 and Caluser2000, thanks for the links and the screenshots!
lolo799
Postby Caluser2000 » 2019-9-01 @ 14:10
lolo799 wrote:That' a bit nitpicking, no? Wasn't Lotus 1-2-3 described as a killer app in its time?
No worries mate. Sharing is caring. Even some of the 20 something year old linux cds I've been going through lately have directories called APPS. As you have implied it is nit picking, the term has been around ever since I've had dealings with computers. Which is from around 1989 or thereabouts.
Yeah Lotus 1-2-3, Word-perfect and Dbase III were all referred to as killer apps.
User avatar
Caluser2000
Postby appiah4 » 2019-9-01 @ 21:07
During the entirety of the 90s my DOS hard drives had \UTILS and \APPS folders. They still do, to be honest.
User avatar
appiah4
PreviousNext
Return to Software
Who is online
