First post, by Caluser2000
As the title suggests this thread is about using the oldest web browser, operating system and REAL (not VMs) hardware to make a post and upload a picture if you or provide a pic using another system. So far I've managed to use a P166mmx testing rig , 1997 era, a number of times running Netscape Communicator 4.x and Turbo Linux 6.0 from 1999.
Just to add a bit extra lets see the most modern browser you can run on the same hardware and OS. For me it has been Opera 9.27 from 2009.
Obviously proof is required by posting pics or screen shots as attachments to your posts.
Have fun.
Reply 1 of 53, by xjas
Challenge accepted.
Thinkpad 365ED
Cyrix/IBM 5x86/100
24MB RAM
Windows 95 OSR2
Opera 4.02
640x480 screen (not so much fun trying to browse)
AWESOME keyboard
3Com PCMCIA 10BT NIC+modem combo card (on my wi-fi via connection sharing from another PC with an auto-negotiating NIC.)
Update: photos - okay, that was a pain in the butt. I edited these on a modern machine & had to waste a couple CD-Rs transferring them over, because the optical drive is on its last legs and apparently won't read blue tinted discs (& never did read -RWs at all.) Still, here they are, and yes, I DID upload all these and am still editing this post on the Thinkpad itself. I'm actually pretty impressed with how well it's handling this, all things considered. This browser runs fine & feels responsive enough on the hardware, it's a shame the internet has bloated to all oblivion.
326.18 KiB
^^ turning off page styles makes the editing dialog box load a bit more reliably, but it does work with them on.
125.1 KiB
^^ man, I forgot that demoscene group even existed. Wonder what happened to the other two who were in it?
180 KiB
177.43 KiB
I haven't fired up this particular browser in probably 15 years. Amusingly, some of the bookmarks I had saved are still around & still look exactly like they did back in the late '90s:
187.23 KiB
Reply 2 of 53, by Caluser2000
Awesome. That's the spirit.
Reply 3 of 53, by Caluser2000
Fired up the 1990 Zenith Z286LP Plus 286/12,8megs,VGA,400megIDE hdd,D-Link DE220 10Mbs nic, connected to a D-Link DES-1005D switch connected directly to the fibre ISP supplied router using CAT5A cabling. Static IP address. Running MS Dos 5a, nic Dos packet driver and ARACHNE v1.97/GPL/286- Web Browser.
1.46 MiB
Will provide pic in a mo..Turned off all images to speed things up. An interesting tidbit is that Bing is the best search engine to use on ARACHNE.
Reply 4 of 53, by BeginnerGuy
Well you already have me beat with the 286 🤣. But I can fire up my 486 (dx2 66, 16mb, win 3.11) later and say hello world from a 486
Sup. I like computers. Are you a computer?
Reply 5 of 53, by Caluser2000
It's really a matter of who is using the oldest kit you've got that can do a post here on the Vogons 😉 Whatever that may be. Have a bit of fun with it as it were. A good thing about Vogons is you can interact with the old stuff and don't need the latest kit.
Reply 6 of 53, by DosFreak
For now but don't think that will go on forever. Security and maintenance are issues and the forums will be getting an upgrade.
So you may have to go through a proxy WebOne - proxy for old browsers to make them Web 2.0-capable when that happens.
Make your games work offline
Reply 7 of 53, by Caluser2000
Wouldn't even worry until that time comes.
Reply 8 of 53, by xjas
Caluser2000 wrote:
Fired up the 1990 Zenith Z286LP Plus 286/12,8megs,VGA,400megIDE hdd,D-Link DE220 10Mbs nic, connected to a D-Link DES-1005D swit […]
Ogod. I remember Arachne being painful on a (different) 5x86 with 64MB RAM. It billed itself as being "fast", but never really was on the type of machines you'd think to use it on. You are a brave man.
I bet this site still works with Lynx / DOSLynx (for now anyway 😉 ) if any of you masochists want to give it a go.
Reply 9 of 53, by Caluser2000
Didn't take long really. It's the 286 or lower version so is quite a bit snapper than the standard one and less crap under the hood. Having tons of EMS helps also. From starting to submitting the post about 5 minutes. I'd trimmed it up quite a while ago so knew I'd have no issues. Faster internet access now as well.
There was a variant of it called Web Spider iirc DR-WebSpyder was it's name:
75.06 KiB
Reply 10 of 53, by Ultrax
Hello from my Compaq Deskpro XE 450 from 1994! This system sports a 486 DX2 running at 50 MHz, 32 MB of RAM, and dual-boots Windows NT 4.0 Workstation SP6 and Windows 95. I'm posting from Opera 4.02, which is realistically the oldest browser I can expect to log in from.
For those of you wondering about NT4 on a 486, it's actually not bad. However, I'm still surprised that it was able to log me in and that I was able to post from it.
I can't get any photos right now, but I will get a screenshot and possibly a photo later on. All text you see here is from this retro PC. 😀
Ultrax
__
Presario 425|DX2-50|8MB|SB V16S|D622/WFW3.11 😎
Deskpro XE 450|DX2-50|32 MB|NT4.0/95
SR2038X|Athlon 64 X2 3800|2G|GT710 WINXP
Dimension 4400|P4 NW 2 GHz|256M|R128U AGP|WINXP
HPMini311|N270|2G|9400M|WINXP
Libretto50CT|P75|16MB|YMF711|WIN95 😎
Reply 11 of 53, by Ultrax
34.49 KiB
(sent from a modern windows 8.1 tablet, unfortunately paint in nt4 cannot save a png so had to convert)
For those wondering, the system has a 3Com Etherlink IITP and was connected directly into the cable modem/router via Cat5e. The page was the correct color, but the screenshot didn't capture it properly.
Ultrax
__
Reply 12 of 53, by Caluser2000
Good effort Ultrax. Nice thing now is ram is only a fraction of the cost, if not free and gives the systems a bit more of an edge. Keep 'm coming folks.
Reply 13 of 53, by hardrivethrutown
Currently Posting from my Windows NT4 system (Pentium II Xeon, 128MB PC100 SDRAM)
Using Opera 10.63 (Not really that old, But it is what I have installed so...)
And if you're wondering why I'm here, Ultrax sent me! 😀
Also VOGONS doesn't like BMPs for some reason so I'll have to sent the screenshot separately
Systems:
- R5 2600, GTX 1070, 16GB
- i7 950, GTX 480, 12GB
- C2Q Q6600, HD3870, 4GB
- Athlon 64 3500+, 6800GT, 2GB
- P4 3.2, FX55008X, 4GB
- P2 400, TNT2, 512MB
- P2 Xeon 400, Elsa PCI Video, 384MB
Reply 14 of 53, by hardrivethrutown
It isn't all that easy to get images off this thing, Mostly network stuff... and Windows 10 and NT4 don't really want to be networked, so I had to pull out my 2 TB Windows Xp file server
    67.62 KiB
Systems:
Reply 15 of 53, by DosFreak
Well since everyone is here posting from 9x or NT4 I'd be interested in what the thoughts are for "best" browser version for slower systems since I'd like to also add information on what browser people should use depending on resources. Possibly withh javascript and ads disabled/hostfile blocks there shouldn't be too much of a diff.
List of Web Browsers For All Operating Systems
For the latest browsers I currently have:
DOS: Links 2.18
Windows 3.x: Opera 3.62 16bit (With Proxy)
Windows 95 4.00.950+ : Opera 10.70 Build 3488 (Primary) / RetroZilla TLS1.2 (Roytam1) (Alternate)
Windows 98-ME (Vanilla) : Opera 10.70 Build 3488 (Primary) / RetroZilla TLS1.2 (Roytam1) (Alternate)
Windows 98/ME (KernelEx w/ Core Update v16): Opera 12.02 Build 1578 (Primary) / K-Meleon 74 (Without Javascript) (Alternate) / Qtweb 3.8.5 (Without Javascript) (Alternate)
Windows NT 3.1-3.50: Opera 3.62 16bit (With Proxy)
Windows NT 3.51: Retrozilla TLS1.2 (Roytam1)
Windows NT4: QtWeb 3.8.4 (Primary) / Opera 10.70 Build 9071 (Alternate) / FireFox 3.6.28 (Roytam1) (Alternate)
Reply 16 of 53, by keenmaster486
286 8 MHz, running MS-DOS 5.0 and Arachne. 3Com 3C509 NIC.
846.84 KiB
World's foremost 486 enjoyer.
Reply 17 of 53, by Caluser2000
DosFreak wrote:
Well since everyone is here posting from 9x or NT4)
Incorrect. "So far I've managed to use a P166mmx testing rig , 1997 era, a number of times running Netscape Communicator 4.x and Turbo Linux 6.0 from 1999."
53.99 KiB
124.82 KiB
This was with 32megs of ram on a P166MMX with 8meg video card. I've since increased the ram to 256megs.
Reply 18 of 53, by Caluser2000
That's the spirit.
Well done.
hardrivethrutown wrote:
Currently Posting from my Windows NT4 system (Pentium II Xeon, 128MB PC100 SDRAM) Using Opera 10.63 (Not really that old, But it […]
Cool. BMPs are quite a bit bigger than other formats. I use Gimp for conversions and it should run on your set up fine. If the distro I'm on doesn't have screen capture tool I just use Gimps Aquire Screen shot tool.
Reply 19 of 53, by hwh
Sounds like a downgrade.
