First post, by Con 2 botones
Hello there.
I am looking for suggestions on a temperature monitoring software. I recently put together a PII 450mhz based system, it is a passively cooled CPU on a small, thick, micro-atx chassis. So I want to control mainly the CPU temperatures (having an eye on chipset wouldn´t harm either).
I´ve added a couple 120mm fans, but the chassis is not designed with airflow in mind, the warm air in the inside seems to not being getting out properly and I´ve noticed the chassis itself gets warm at touch, not to mention the CPU heatsink which gets hot.
Do you happen to use or know about a piece of software suitable and compatible with Windows 98se, for this purpose?
Think in advance!
Reply 3 of 4, by agent_x007
You could try Everest Home or Ultimate.
HWInfo : LINK
Reply 4 of 4, by Con 2 botones
I could search for an old version of Everest which works on Windows98, yes.
I believe I´ve tried HWinfo before but didn´t pay attention on its temperature monitoring capabilities
Thanks!
