Reply 20 of 48, by Damionsux
Jorpho wrote on 2020-03-29, 05:17:
Damionsux wrote on 2020-03-28, 23:09:
Here’s an update to the imgur album with the changes
https://imgur.com/a/SFZJ60r
You realize you have a CONFIG.BAT in that album, right? I hope you haven't been trying to make changes to that. You also still have several instances of /E:OPTICAL in there.
For the purpose of figuring out what the problem is, you can just type out the commands in AUTOEXEC.BAT manually if you want.
Yes, I noticed all those too- I deleted them. I only have one config.sys now, it’s in the c:\dos folder.
The autoexec I got from Phil’s computer lab dot com, honestly I have very little knowledge of dos, obviously this experience is changing that 🤣
Reply 21 of 48, by CoffeeOne
Damionsux wrote on 2020-03-29, 14:15:
derSammler wrote on 2020-03-29, 08:28:
I'm not sure if the problem has to do with the cd drive at all. Sounds like a more serious hardware issue to me.
Could you please try booting from the Win95 or 98 boot floppy disk? It has CD-ROM support. Check if that is working.
That for sure is working
Sorry to say, but better give up. Seems to be too hard to explain to you.
Most likely you always edit a file named config.bat. So your config.sys does not change at all.
But seriously, I would recommend that you use a straight forward configuration without sections.
So NO [common] [menu] menuitem and no goto, bla bla. Just a straight forward config.sys and autoexec.bat, where the commands are listed.
That will make it more simple for you.
Reply 22 of 48, by CoffeeOne
Damionsux wrote on 2020-03-29, 14:18:
config.sys can't be in C:\dos. If it is there, it does nothing. The config.sys is in the top level folder, the path is C:\config.sys. The same is true for autoexec.bat
Reply 23 of 48, by derSammler
In case you really modify the files in the wrong place: Windows up to 9x had a tool called "sysedit.exe", which automatically opens config.sys, autoexec.bat, win.ini, system.ini, etc. for editing. This way, you don't have to know where they are located.
Assuming or tested? Because it uses OAKCDROM.SYS as well and if it works from floppy, it must work from hard disk as well.
Reply 24 of 48, by Damionsux
derSammler wrote on 2020-03-29, 15:54:
I don't have a working floppy disk, the drive works presumably, but the two disks I have are trash. I am able to get the Win98 cdrom going from an OEM copy- that is how I installed 98...
The cd rom issue seems to be intermittent now, sometimes it works sometimes it screams at me, and now sometimes it hangs on the ctmouse driver- I'm almost ready to call it quits 🤣
Reply 25 of 48, by Damionsux
CoffeeOne wrote on 2020-03-29, 15:48:
lemme do that too
Reply 26 of 48, by Damionsux
CoffeeOne wrote on 2020-03-29, 15:39:
Sorry to say, but better give up. Seems to be too hard to explain to you. Most likely you always edit a file named config.bat. S […]
I mean, you're not wrong, I am completely ignorant to DOS, and I guess being a member of this group implies that I can follow simple instructions. Sorry to say- I clearly am not able to- so I should just give up! Such astute advice!
Reply 27 of 48, by Damionsux
Damionsux wrote on 2020-03-29, 17:18:
as per user: CoffeeOne I should just give up. Seems like sound advice since the buzzer is screaming at me anyway once again- after adding the config.sys into the root of c:\
Reply 28 of 48, by CoffeeOne
Damionsux wrote on 2020-03-29, 17:31:
OK, Let's try a bit more 😀
Can you post here in txt format
your c:\config.sys
and your c:\autoexec.bat
Reply 29 of 48, by Damionsux
I realized that yes, and deleted the other garb. I just have one config.sys now
Reply 30 of 48, by CoffeeOne
Damionsux wrote on 2020-03-29, 17:37:
Can you post both files here, please?
As text not as picture, if possible? Maybe that's difficult because probably you can't transfer the files easily.
OK, then as picture might be good, too 😁
Reply 31 of 48, by CoffeeOne
Can you try that?
C:\config.sys
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\EMM386.EXE RAM
DOS=HIGH,UMB
DEVICEHIGH=C:\DOS\OAKCDROM.SYS /D:OPTICAL
FILES=40
BUFFERS=40
LASTDRIVE=H
C:\autoexec.bat
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
LH C:\DOS\MSCDEX.EXE /D:OPTICAL /L:F
LH C:\DOS\CTMOUSE.EXE
Let's add the missing staff later on, when the CD ROM works.
Reply 32 of 48, by Damionsux
I think I have narrowed the issue down, not only was that autoexec and config not working for me, but I was also using phils restart in msdos mode shortcut, and therein lies several of the same issues in those lines too. I was looking at the advanced configuration and it calls to the same config.sys that was giving me grief before.
Reply 33 of 48, by Damionsux
so, If I F8 and choose command prompt then run the autoexec file, I do not get the error. But then the computer will hang if I try to run Rise Of the Triad off the disc...
Reply 34 of 48, by Damionsux
Damionsux wrote on 2020-03-29, 22:37:
literally anything causes the computer to hang now... quake, duke3d, doom
something is seriously messed up
Reply 35 of 48, by Lylat1an
Can you copy and paste the contents of your autoexec.bat and config.sys files so we can see them here?
Reply 36 of 48, by derSammler
To quote myself:
derSammler wrote on 2020-03-28, 19:13:
Please give some more info about the hardware used. It's rather unlikely that trying to access the CD-ROM drive causes the system to hang.
Reply 37 of 48, by CoffeeOne
AAARRRRRRGGGGGGGGHHHHHHHHH
F8?
So you are using Windows 95?
I thought you are using pure MS-DOS.
When you are using Windows 95 or Windows 98 you should not use the DOS version of HIMEM.SYS and EMM386.EXE at all. Please only use the Windows version (most likely located in C:\WINDOWS).
Reply 38 of 48, by derSammler
He's using Win98SE, as he told already in his second post. 😉
Reply 39 of 48, by CoffeeOne
Omg, you are right, I mixed up something.
Now I have to a apologize.
@Damionsux
So as already mentioned, what you did, does not work in principle.
You copied over files from philscomputerlab, which are meant for pure DOS.
Windows 98 has other versions of himem.sys and emm386.exe for example, DO NOT USE the MS-Dos version of it to run the DOS part of Windows 98 SE. By the way it is called DOS 7.1 as far as I know.
You can make a boot menu in windows 98se, too. But it works slightly different, so you can't follow the guide (and most important use wrong versions of essential files) of philscomputerlab
EDIT: As a quick fix of your now broken Windows 98 SE installation, you can make c:\config.sys c:\autoexec.bat completely empty (yes, really)
Windows 98 will load everything what is essential by itsself
