Floppy disk imaging - what program to use?
First post, by cyclone3d
Just got a couple 720KB floppy disks I need to image.
I normally use RawWrite for Windows, but although it reads the 720KB floppies just fine, it creates 1.44MB images.
http://www.chrysocome.net/rawwrite
I see mention of WinImage quite a lot but not sure I really want to buy a license for it although I might just go ahead and do that.
I did find another program, OmniFlop which looks like it will work just fine and is free - anybody have any experience with this?:
http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm
And here is another program that popped up- FloppyBase 1.6 - looks like it may only work on up to XP though (will only work on 32-bit Windows):
https://www.hammer-software.com/legacy-downloads/
Any other floppy imaging programs I should know about? Maybe we could make this thread into a list?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 24, by derSammler
You don't need a license for WinImage. The free version only lacks features you are not going to use anyway. It's what I'd recommend if you do the imaging on a Windows system. Get version 8.5, that was the best one (https://www.winimage.com/download/winima85.zip).
OmniFlop is overkill for just imaging ordinary disks. It's more useful for exotic formats.
Reply 3 of 24, by Caluser2000
If you have a linux box laying around here's a nice tutorial.
https://untitledfinale.wordpress.com/2007/10/ … es-under-linux/
Reply 4 of 24, by zerodiagonal
derSammler wrote on 2020-05-29, 07:02:
I use 9.00, just curious why you recommend 8.5 over the rest. Haven't faced any major issues but I only use WinImage for regular 1.44 disks.
Reply 5 of 24, by pii_legacy
Omnidisk is great for running in DOS, that's my go-to when i'm not on Win2k or higher.
rmay635703 wrote on 2020-05-29, 03:40:
On a vintage system Herne data systems software works great
http://www.herne.com/mdisk1.htm
Are its image files non-proprietary? Interested if it is compatible with Linux / OmniFlop
Reply 6 of 24, by rmay635703
pii_legacy wrote on 2020-05-30, 11:25:
They are raw not compressed and may have a header and may use Unix characters and the like to represent raw data.
But those issues can be worked through just viewing the file in a hex editor
Reply 7 of 24, by Robin4
Whats the best utility to use when needed re-read again and again to get the data from a floppy disk?? Something that can do low-level reading. So if the disk is bad, so still could get all the data from the disk.
Does anybody knows what Adrian Black uses to image/ backup these disks (that guy from youtube)
Reply 8 of 24, by Disruptor
I use VGACopy for image purposes in DOS.
Reply 9 of 24, by Robin4
That VGAcopy program uses a minium of 386 system to work?
Is there a version which also works on PC XT or 286?
Dont know if vgash103.zip is the same? But iam guess not?
Reply 10 of 24, by Disruptor
It requires a 386
Reply 11 of 24, by Robin4
The older version seems to not being available (dont know if there is something which could run on a 8086 or 286 as well.)
If i could buy a license i would do if the software is great working with.
Reply 12 of 24, by Jo22
On a modern PC, I'm using WinImage 8.x (previously 6.x) occasionally. On Windows, of course.
Mac and Linux still lack a user friendly counterpart (except for special solutions such as FC5025 or KyroFlux).
On a 286+ vintage PC, I'm using WinImage 3.x on Windows 3.1 running Standard Mode.
On a PC/XT compatible PC (808x) and plain DOS, I use Disc Copy Fast (DCF). In the past, I used to use QCopy 4.x here.
Reply 13 of 24, by Martin8bity
ImageDisk (IMD) from Dave Dunfield is great in DOS: http://dunfield.classiccmp.org/dos/index.htm It is also advantage to have good floppy controller chip, such as PC8477.
Reply 14 of 24, by Robin4
Martin8bity wrote on 2021-08-29, 09:29:
So i need to use an old style controller without that multi io thingy?
Thanks for the tip on image disk.
Reply 15 of 24, by zyga64
Back in time very popular was DiskDupe (at least in Poland).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 16 of 24, by Martin8bity
Robin4 wrote on 2021-08-30, 01:47:
... good floppy controller chip, such as PC8477.
There are different floppy controllers with different capabilities. I found the PC8477 to be great, you can find it sometimes on Adaptec ISA SCSI cards or you can build yourself a Floppy interface. I did some few years ago https://www.8bity.cz/2013/postavte-si-pcxt-3-disketov-radic/, the projects are Open Source.
Theres is TESTFDC.COM program in IMD.ZIP, that will show you the controller capabilities.
Reply 18 of 24, by Robin4
Martin8bity wrote on 2021-08-30, 07:41:
Thanks, nice to know. Taken some time and test this out.
Reply 19 of 24, by Robin4
Martin8bity wrote on 2021-08-30, 08:17:
There is also a special hardware to read/copy/preserve floppies, such as KryoFlux https://www.kryoflux.com/, FluxEngine https://github.com/davidgiven/fluxengine or Greaseweazle https://github.com/keirf/Greaseweazle, but this is getting off topic.
I think iam going to use software first. Then i dont have to spend so much of money for nothing.
But maybe it is a last resort, if iam out of other options.
