First post, by PlaneVuki
Hello.
Is there an easy way, maybe a program or something, to Delete Directory Tree on older DOS, kinda like DELTREE, which won't work on DOS versions below 6.0.
I am using older DOS versions because installation is a lot faster (6.22 is 3 floppies!) and 6.22 has nothing new that I need.
But, deleting Directory Trees can be a real pain sometimes.
I mostly use DOS 5.0
Thanks in advance.
Reply 2 of 6, by PlaneVuki
Thanks, I will try both and get back with the results.
Reply 3 of 6, by PlaneVuki
Thanks for help. Deltree of Freedos works!
Like normal DOS, Doshell also can't delete non-empty folders.
Reply 4 of 6, by obaltus
You can try:
rd not_empty_folder /q /s
Reply 6 of 6, by GigAHerZ
My go-to tool has been Norton Commander, and this can delete non-empty directories as well.
