Recent WinXP/POS2009 update causes errors with PIII systems
Reply 80 of 86, by feipoa
That's curious. I guess the corona virus has infected Microsoft's servers as well.
Reply 81 of 86, by nd22
As of yesterday, October 5 2020 Windows XP update & Microsoft update for XP no longer work and shows the same error as before!
Reply 82 of 86, by RichB93
XP slows to a crawl SP3 onwards, I wouldn't bother patching unless you're using any apps on there that actually need it. It's not as if you'd want to use it for Internet browsing anyway.
Reply 83 of 86, by feipoa
XP SP3 w/ all updates thru 2019 runs fine of my Lenovo T61. Mypal browser runs OK and has regular updates.
Reply 84 of 86, by nd22
XP runs just fine on many old systems as long as it is not connected to the internet! I have assembled over 40 systems and XP is installed on the majority of them form 1400s with 1.5gb of ram where it is usable going through P4/Athlon Xp with 2gb of ram where it is good but not great up to to FX-60 with 4gb of ram where it flies!
Reply 85 of 86, by Falcosoft
nd22 wrote on 2020-10-09, 08:21:
XP runs just fine on many old systems as long as it is not connected to the internet! ...
No one told that XP would not run great on older or even newer systems. Richb93 just questioned why it is good to patch XP beyond SP3 (or even SP2?) if you do not want to connect it to internet anyway...
It can be argued that POS updates can cause more troubles than benefits. There are no XP compatible programs/games that can only run on XP when POS updates are installed. And these updates do not speed up XP any way to say the least. Not to mention problems with processors lacking SSE2, MS installer errors and other quirks caused by these updates.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 86 of 86, by zapbuzz
I made an XP PRO DVD disc with updates and drivers but deliberately left out POS updates so I can install on non SSE2 machines. The Legacy Update site (https://legacyupdate.net/) has all the POS updates if I need them instead. I tried a POS 09 2018 patched windows XP it didn't work well at all on a p3 coppermine machine. Pity.
