Reply 20 of 25, by keenmaster486
- l33t
I've run it on my Pentium III - 800MHz with a Voodoo 3 and it's quite smooth. I had to apply the Voodoo3 patch.
World's foremost 486 enjoyer.
Moved to Marvin -> Software.
do the Fandango!" - Queen
Stiletto
Overclocked my CPU to 233 MHz and the game became 30+ fps playable with Far draw distance (not full) and everything else set to high so it has a strange CPU barrier at around 200MHz. Very strange.
Wasn't your CPU already running at 233 MHz?
wrote:Wasn't your CPU already running at 233 MHz?
Wait you are right. I had the issue the other day but it was fluid last night so I assumed the overclock had fixed it. However apparently it was something else entirely because the low framerate issue appears to have happened on 233 MHz as well. Ultimately I have no idea what it was.. or why it went away..
Computers man, love 'em or hate 'em 🤣 .
