DOSfan1994 wrote:You can't use MS-DOS 6.22 for FAT32 8gig partitions.
PC-DOS 7.1 is your friend then!
But FAT32 and DOS is pointless. If you want FAT32 and DOS, then your system is powerful enough to run Windows 95 B or OS/2 Warp.
DOS doesn't NEED more than 2GB of space, and unless your loading 20 DOOM installs (I raise my hand) you don't need much more than 500 MB most of the time.
But that's not what has stopped anybody
PC-DOS 7.1 has the IBM coolness factor (Who doesn't like IBM, it's like your grandfather or uncle, they try their very best, but everybody ends up stealing their work) and
MS-DOS 7.1 from the China DOS union is definitely an option.
You could also install 95B, and strip all the UI elements out until your left with MS-DOS 7.1, but my advice for that is to probably try and use the sys command if that exists in 95B to copy onto a floppy, move utilities like FDISK onboard, and then go back and do the reverse.
FreeDOS is an option, but it has the disappointment of being not retro. Personally I take qualm with this, I prefer period accuracy vs. modern convenience, so I'd rather swap 12 floppies instead of getting a USB floppy emulator and sit there clicking buttons. It might be useful, it might be fast, and it might save your hair when and if normal floppies would go wrong, but we are here for the retro experience.
My opinions aside, DR-DOS is also something you could try, but I am not sure if it has FAT32 support.
