First post, by Robhalfordfan
- Oldbie
I have two hdd and going to install multiple OS and use a third party boot manager with it and in my pc and try to install windows 2000 on the second hdd but everytime I do, it says it needs to write startup files on first hdd
when unplug the first hdd and install windows 2000 on the second hdd (without first hdd being pluged in) and it installs no problem but as soon plug the first hdd back in, windows 200 doesn't boot as I only get a blinking line in top left corner
is that a way to install boot windows 2000 on a second hdd (not the first) and boot no problem as I wanna use the first for xp since as more space
with the third party boot manager, i can hide the partitions from showing up in in any windows i install (so they don't clash with each other), so each os have the own partition and cant see any other os partition, so they think they have there own c drive - if that makes sense
