First post, by darklord04
Hi guys i am new here, the names Dane and i am hoping you folks can help. Recently i built a retro rig running a Pentium III 800mhz cpu , around 326 mb or ram and a radeon 9550 agp gfx card with 128 vram. The hard drive is an 89 gig ide drive. So my issue is this both windows 98SE and windows ME install fine, i install all drivers everything is working even my usb headset, however the mouse lags like crazy especially if i try to install something or if im extracting an archive, its as if the entire computer slows to a crawl when in operation with a task, strangely games work find with no lag at all only when im in desktop view doing desktop things or when running my old version of firefox to download patches etc.
Even more strange is the fact that the system runs perfect on windows 2000 and XP so I am really at a loss as to what is causing the slowdowns, it has been around 16 years since i last used this older tech and os's so any help would be appreciated thanks.
Reply 1 of 10, by darklord04
here is the dxdiag i took as well for full system info
System Information
Time of this report: 4/14/2017, 12:35:04
Machine name: D2J7H1
Operating System: Windows Me (4.90, Build 3000)
Language: English (Regional Setting: English)
System Manufacturer: Viglen
System Model: Win98
BIOS: Intel
Processor: Intel Pentium III, ~800MHz
Memory: 384MB RAM
Page File: 0MB used, 1664MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 4.09.0000.0904 32bit
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file ATI2DRAG.DRV is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. Direct3D 7 test results: The tests were cancelled before completing. Direct3D 8 test results: The tests were cancelled before completing. Direct3D 9 test results: The tests were cancelled before completing.
Sound Tab 1: The file USBAUDIO.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9550
Manufacturer: ATI Tech. - Enhanced
Chip type: RADEON 9550 AGP (0x4153) Rev 0
DAC type: Internal
Device Key: Enum\PCI\VEN_1002&DEV_4153&SUBSYS_0200174B&REV_00\000800
Display Memory: 255.0 MB
Current Mode: 1280 x 1024 (32 bit)(75Hz)
Monitor: BenQ GL2250
Monitor Max Res: 1600,1200
Driver Name: ATI2DRAG.DRV
Driver Version: 4.14.0001.9150 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 1/18/2005 03:33:08, 85232 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: *vdd,*vflatd
Mini VDD: ATI2VXAG.VXD
Mini VDD Date: , 0 bytes
Device Identifier: {D7B71EE2-0213-11CF-0C74-0122A1C2C935}
Vendor ID: 0x1002
Device ID: 0x4153
SubSys ID: 0x0200174B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: The tests were cancelled before completing.
D3D8 Test Result: The tests were cancelled before completing.
D3D9 Test Result: The tests were cancelled before completing.
Sound Devices
Description: USB Audio Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_1B1C&PID_0A06&MI_00\0000USB&VID_1B1C&PID_0A06&INST_0
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 4.90.3001.0000 (English)
WHQL Logo'd: No
Date and Size: 12/13/2000 15:14:08, 51344 bytes
Other Files: USBAUDIO.sys
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: AC'97 Sound Card
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: PCI\VEN_8086&DEV_2445&SUBSYS_45418086&REV_02\BUS_00&DEV_1F&FUNC_05
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ichaud.sys
Driver Version: 4.90.2509.0000 (English)
WHQL Logo'd: Yes
Date and Size: 6/8/2000 17:00:00, 36240 bytes
Other Files: ichaud.sys
Cap Flags: 0xB5B
Min/Max Sample Rate: 8000, 48000
Static/Strm HW Mix Bufs: 1, 0
HW Memory: 0
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0x400
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\system32\drivers\gm.dls
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
AC'97 Sound Card, Software (Kernel Mode), Output, DLS, Internal
USB Audio Device, Software (Kernel Mode), Output, DLS, Internal
MIDI Mapper, Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth, Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401, Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401, Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Mad Catz V.5 Keyboard
Attached: 1
Controller ID: n/a
Vendor/Product ID: 0x0738, 0x2026
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Raptor HS40
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1B1C, 0x0A06
FF Driver: n/a
Poll w/ Interrupt: Yes
Registry: OK
USB Devices
Gameport Devices
PS/2 Devices
DirectPlay Service Providers
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0904)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: VIA PCI 10/100Mb Fast Ethernet Adapter -
DirectPlay8 TCP/IP Service Provider: Intel(R) PRO Adapter -
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 32.6 GB
Total Space: 38.2 GB
File System: FAT32
Model: IDE DISK TYPE47
Drive: D:
Model: LITE-ON DVDRW LH-20A1P
Drive: E:
Model: MagicISO Virtual DVD-ROM
DirectX Components
ddraw.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 399872 bytes
ddraw16.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 28496 bytes
ddrawex.dll: 4.87.0000.0700 English Final Retail 6/8/2000 17:00:00 36864 bytes
ddraw.vxd: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 30469 bytes
ddhelp.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dxapi.sys: 4.87.0000.0700 English Final Retail 6/8/2000 17:00:00 2416 bytes
d3d8.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 1234944 bytes
d3d9.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 1660928 bytes
d3dim.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 638976 bytes
d3dim700.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 892416 bytes
d3dref.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 155648 bytes
d3dramp.dll: 4.07.0000.0700 English Final Retail 6/8/2000 17:00:00 606208 bytes
d3drm.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 446464 bytes
d3dxof.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 118784 bytes
d3dpmesh.dll: 4.06.0002.0436 English Final Retail 6/8/2000 17:00:00 102400 bytes
dplay.dll: 4.03.0000.1096 English Final Retail 6/8/2000 17:00:00 57344 bytes
dplayx.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 241664 bytes
dpmodemx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 90112 bytes
dpwsock.dll: 4.03.0000.1096 English Final Retail 6/8/2000 17:00:00 40960 bytes
dpwsockx.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 90112 bytes
dplaysvr.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 40960 bytes
dpnsvr.exe: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 28672 bytes
dpnet.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 720896 bytes
dpnlobby.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 16384 bytes
dpnaddr.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 16384 bytes
dpvoice.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 385024 bytes
dpvsetup.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes
dpvvox.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 122880 bytes
dpvacm.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dpnhpast.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 45056 bytes
dpnhupnp.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 73728 bytes
dpvhelp.exe: 4.07.0001.3000 English Final Retail 6/8/2000 17:00:00 84752 bytes
dpserial.dll: 4.03.0000.1096 English Final Retail 6/8/2000 17:00:00 49152 bytes
dinput.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 667648 bytes
dinput8.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 692224 bytes
dinput.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 10874 bytes
dimap.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 94208 bytes
diactfrm.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 466944 bytes
vjoyd.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 33882 bytes
joyhid.vxd: 4.88.0001.0881 English Final Retail 12/12/2002 00:14:32 13067 bytes
joy.cpl: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 442368 bytes
gcdef.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 491520 bytes
gchand.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 6656 bytes
pid.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 40960 bytes
gameenum.sys: 4.07.0001.3000 English Final Retail 6/8/2000 17:00:00 10608 bytes
hidgame.sys: 4.07.0001.3000 English Final Retail 6/8/2000 17:00:00 8912 bytes
msanalog.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 12745 bytes
msjstick.drv: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 2352 bytes
dsound.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 509440 bytes
dsound3d.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1331200 bytes
dsound.vxd: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 49666 bytes
dswave.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 17920 bytes
dsdmo.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 489984 bytes
dmusic.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 122880 bytes
dmusic16.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 10992 bytes
dmusic32.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 28672 bytes
dmband.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 26624 bytes
dmcompos.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 57856 bytes
dmime.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 180736 bytes
dmloader.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes
dmstyle.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 98304 bytes
dmsynth.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 100352 bytes
dmscript.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 76288 bytes
system.dll: 1.01.4322.2032 English Final Retail 4/14/2017 12:33:34 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 4/14/2017 12:31:26 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 4/14/2017 12:31:18 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 4/14/2017 12:31:18 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 4/14/2017 12:31:18 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 4/14/2017 12:31:18 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 4/14/2017 12:31:20 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 4/14/2017 12:31:26 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 4/14/2017 12:31:26 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 4/14/2017 12:31:26 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 4/14/2017 12:31:26 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 4/14/2017 12:31:26 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:26 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:26 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:32 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:32 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:26 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:26 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 4/14/2017 12:31:26 223232 bytes
dx7vb.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 602112 bytes
dx8vb.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 4.09.0000.0904 English Final Retail 7/9/2004 04:27:28 1720320 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 6/8/2000 17:00:00 933888 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:44 1028096 bytes
wsock32.dll: 4.90.0000.3000 English Final Retail 4/14/2017 09:37:28 36864 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 65024 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 134656 bytes
dxmasf.dll: 6.04.0007.1121 English Final Retail 9/21/2001 14:44:32 498448 bytes
mciqtz.drv: 4.00.0096.0729 English Final Retail 12/12/2002 00:14:32 11776 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 135168 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 12800 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 173056 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 311808 bytes
qdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 445952 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1795584 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1845248 bytes
quartz.vxd: 4.00.0000.0501 English Final Retail 12/12/2002 00:14:32 5672 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 10:52:08 246814 bytes
vidx16.dll: 0.00.0000.0000 English Final Retail 12/12/2002 00:14:32 10240 bytes
iac25_32.ax: 2.00.0005.0050 English Final Retail 6/8/2000 17:00:00 198656 bytes
ir41_32.ax: 4.31.0016.0002 English Final Retail 6/8/2000 17:00:00 857600 bytes
ir41_qc.dll: 0.00.0000.0000 English Final Retail 6/8/2000 17:00:00 135168 bytes
ir41_qcx.dll: 0.00.0000.0000 English Final Retail 6/8/2000 17:00:00 352256 bytes
ir50_32.dll: 5.1026.0015.0041 English Final Retail 6/8/2000 17:00:00 753664 bytes
ir50_qc.dll: 5.00.0063.0038 English Final Retail 6/8/2000 17:00:00 212992 bytes
ir50_qcx.dll: 5.00.0064.0038 English Final Retail 6/8/2000 17:00:00 196608 bytes
ivfsrc.ax: 5.03.0002.0038 English Final Retail 6/8/2000 17:00:00 139264 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324608 bytes
msdvdopt.dll: 4.90.3000.0000 English Final Retail 6/8/2000 17:00:00 74512 bytes
ks.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 126976 bytes
ksproxy.ax: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 117760 bytes
ksuser.dll: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 46080 bytes
mspclock.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 4.90.3000.0000 English Final Retail 6/8/2000 17:00:00 4848 bytes
mskssrv.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 4.90.3010.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:08 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:10 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:54 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:22 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:30 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:14 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 02:58:40 56832 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:14 8448 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:34 14464 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 02:59:06 481792 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:32 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:12 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:12 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:36 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:10 16896 bytes
kstvtune.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:00:24 274432 bytes
ksxbar.ax: 5.03.0000.0900 English Final Retail 7/9/2004 02:58:34 39936 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 03:00:24 226304 bytes
vfwwdm32.dll: 4.90.0000.3000 English Final Retail 6/8/2000 17:00:00 69632 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 02:59:42 47104 bytes
msdv.sys: 4.90.3010.0900 English Final Retail 7/9/2004 02:58:50 46080 bytes
Inactive Display Entries in Registry
Card name: RADEON 9550 Secondary
Driver: ATI2DRAG.DRV
Inactive Sound Entries in Registry
None
DirectShow Filters
WDM Streaming Capture Devices:
AC'97 Sound Card,0x00200000,2,2,,4.90.3010.0900
,0x00000000,0,0,,
USB Audio Device,0x00200000,2,2,,4.90.3010.0900
WDM Streaming Communication Transforms:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,4.90.3010.0900
WDM Streaming Data Transforms:
Microsoft Kernel DRM Descrambler Filter,0x00200000,1,1,,4.90.3010.0900
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,4.90.3010.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,4.90.3010.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Audio Mixer,0x00200000,2,2,,4.90.3010.0900
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
WDM Streaming Tee/Splitter Devices:
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,4.90.3010.0900
AC'97 Sound Card,0x00200000,14,4,,4.90.3010.0900
USB Audio Device,0x00200000,4,2,,4.90.3010.0900
DirectShow Filters:
WMAudio Decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
MSScreen decoder DMO,0x00600800,1,1,,
Indeo® video 5.04 Decompression Filter,0x00640000,1,1,IR50_32.DLL,5.1026.0015.0041
Indeo® video 5.04 Compression Filter,0x00200000,1,1,IR50_32.DLL,5.1026.0015.0041
Indeo(R) audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0050
IVF source filter,0x00600000,0,1,IVFSRC.AX,5.03.0002.0038
Cutlist File Source,0x00200000,0,1,QCUT.DLL,6.02.0011.0608
Lyric Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
XML Graphbuilder,0x00400000,0,0,QUARTZ.DLL,6.05.0001.0902
XTL Loader,0x00400000,0,0,QEDIT.DLL,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,ACELPDEC.AX,1.04.0000.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,MPG4DS32.AX,4.01.0000.3857
ClearVideo® Decompression Filter,0x00800000,1,1,CLRAMD.AX,2.00.0000.0001
TrueMotion 2.0 Decompressor,0x00600001,1,1,TM20DEC.AX,2.00.0006.0006
VIVO Audio Decoder Filter,0x00800002,1,1,VVAUDFLT.AX,3.00.0000.0001
VIVO Video Decoder Filter,0x00600001,1,1,VVVIDFLT.AX,3.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,MSADDS32.AX,7.00.0000.1440
Internal LMRT Renderer,0x00800001,1,0,LMRTREND.DLL,6.01.0005.0124
URL StreamRenderer,0x00600000,1,0,LMRTREND.DLL,6.01.0005.0124
ShotBoundaryDet,0x00200000,1,1,WMMFILT.DLL,1.00.1376.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,WMMFILT.DLL,1.00.1376.0000
Windows Media Video Decoder,0x00800000,1,1,WMVDS32.AX,7.00.0000.1440
WMP CD Filter,0x00600000,0,1,WMPCD.DLL,7.00.0000.1440
Microsoft Screen Video Decompressor,0x00800000,1,1,MSSCDS32.AX,7.00.0000.1440
Windows Media source filter,0x00600000,0,2,DXMASF.DLL,6.04.0007.1121
ASF DIB Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF ACM Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF ICM Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF URL Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF JPEG Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF DJPEG Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASF embedded stuff Handler,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASX file Parser,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
ASX v.2 file Parser,0x00600000,1,0,DXMASF.DLL,6.04.0007.1121
XML Playlist,0x00400000,1,0,DXMASF.DLL,6.04.0007.1121
.RAM file Parser,0x00600000,1,0,DXMASF.DLL,6.04.0007.1121
NSC file Parser,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
Windows Media Multiplexer,0x00600000,1,1,DXMASF.DLL,6.04.0007.1121
File Source (Netshow URL),0x00400000,0,1,DXMASF.DLL,6.04.0007.1121
Windows Media Update Filter,0x00400000,1,0,DXMASF.DLL,6.04.0007.1121
WM ASF Reader,0x00400000,0,0,QASF.DLL,6.05.0001.0900
WM ASF Writer,0x00400000,0,0,QASF.DLL,6.05.0001.0900
AVI Mux,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
File writer,0x00200000,1,0,QCAP.DLL,6.05.0001.0900
Infinite Pin Tee Filter,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Smart Tee,0x00200000,1,2,QCAP.DLL,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,QDV.DLL,6.05.0001.0900
DV Muxer,0x00400000,0,0,QDV.DLL,6.05.0001.0900
DV Splitter,0x00600000,1,2,QDV.DLL,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,QDVD.DLL,6.05.0001.0900
Overlay Mixer2,0x00400000,1,1,QDVD.DLL,6.05.0001.0900
Line 21 Decoder,0x00600000,1,1,QDVD.DLL,6.05.0001.0900
DVD Navigator,0x00200000,0,2,QDVD.DLL,6.05.0001.0900
SampleGrabber,0x00200000,1,1,QEDIT.DLL,6.05.0001.0900
Null Renderer,0x00200000,1,0,QEDIT.DLL,6.05.0001.0900
AVI/WAV File Source,0x00400000,0,2,QUARTZ.DLL,6.05.0001.0902
AVI Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Draw,0x00600064,9,1,QUARTZ.DLL,6.05.0001.0902
Color Space Converter,0x00400001,1,1,QUARTZ.DLL,6.05.0001.0902
VGA 16 Color Ditherer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Full Screen Renderer,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Renderer,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Video Mixing Renderer 9,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Video Decoder,0x40000001,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG-I Stream Splitter,0x00600000,1,2,QUARTZ.DLL,6.05.0001.0902
File Source (Async.),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
QT Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
AVI Splitter,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Wave Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
ACM Wrapper,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
MIDI Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
Internal Script Command Renderer,0x00800001,1,0,QUARTZ.DLL,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File stream renderer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902
File Source (URL),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902
MJPEG Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902
Line 21 Decoder 2,0x00600002,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.09.0000.0311
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PSISRNDR.AX,6.05.0001.0900
VBI Surface Allocator,0x00600000,1,1,VBISURF.AX,5.03.0000.0900
MPEG-2 Demultiplexer,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
MPEG-2 Splitter,0x005fffff,1,0,MPG2SPLT.AX,6.05.0001.0900
AC3 Parser Filter,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,MPEG2DATA.AX,6.05.0001.0900
WST Decoder,0x00600000,1,1,WSTDECOD.DLL,5.03.0000.0900
Indeo® video 4.3 Decompression Filter,0x00640000,1,1,IR41_32.AX,4.31.0016.0002
Indeo® video 4.3 Compression Filter,0x00200000,1,1,IR41_32.AX,4.31.0016.0002
Voxware MetaSound Audio Decoder,0x00999999,1,1,VOXMSDEC.AX,1.00.0000.0012
Voxware MetaVoice Audio Decoder,0x00999998,1,1,VOXMVDEC.AX,1.00.0000.0011
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
MJPEG Compressor,0x00200000,0,0,QUARTZ.DLL,6.05.0001.0902
DV Video Encoder,0x00200000,0,0,QDV.DLL,6.05.0001.0900
Indeo® video 5.04 Compression Filter,0x00100000,1,1,IR50_32.DLL,5.1026.0015.0041
VDOnet VDOWave,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Cinepak Codec by Radius,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Indeo® video 5.04,0x00200000,1,1,QCAP.DLL,6.05.0001.0900
Audio Capture Sources:
USB Audio Device,0x00200000,0,0,QCAP.DLL,6.05.0001.0900
AC'97 Sound Card,0x00200000,0,0,QCAP.DLL,6.05.0001.0900
Audio Compressors:
WMAudio Encoder DMO,0x00600800,1,1,,
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
PCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
ACELP.net,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
GSM 6.10,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
IAC2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902
Audio Renderers:
USB Audio Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
AC'97 Sound Card,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
DirectSound: USB Audio Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
DirectSound: AC'97 Sound Card,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
Midi Renderers:
Microsoft GS Wavetable SW Synth,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
MPU-401,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902
Default MidiOut Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,4.90.3010.0900
BDA Receiver Component:
BDA MPE Filter,0x00600000,1,1,,4.90.3010.0900
BDA Slip De-Framer,0x00600000,1,1,,4.90.3010.0900
WDM Streaming VBI Codecs:
CC Decoder,0x00200000,2,1,,4.90.3010.0900
NABTS/FEC VBI Codec,0x00200000,2,1,,4.90.3010.0900
WST Codec,0x00200000,1,1,,4.90.3010.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PSISRNDR.AX,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,MPEG2DATA.AX,6.05.0001.0900
Reply 4 of 10, by Jorpho
You may need the Intel Application Accelerator to enable DMA.
https://downloadcenter.intel.com/download/485 … ion-Accelerator
I'm not sure that will help with your problem, but it's worth a try.
Reply 5 of 10, by darklord04
So just read up on that setting doesn't look like my hard drive has the ability to enable it sadly , is there any other options ? Or if not can you guys recommend a good hard drive mak with ideally the model
Reply 9 of 10, by chinny22
What motherboard do you have?
P3 and a 80GB hard drive are both well into when DMA was common.
Also your not using a IDE to SATA adaptor are you, some of those don't allow DMA?
Reply 10 of 10, by KT7AGuy
Install the Intel INF v3.20.1008 chipset drivers (infinst_enu.exe). Check the readme.txt before installing.
https://downloadcenter.intel.com/download/424 … Series-Chipsets
Intel Application Accelerator (iaa23_multi.exe) (iaa23_enu.exe)
If you're using an Intel i810 or i815, you may get some performance improvement by installing the Intel Application Accelerator v2.3. Then again, this might cause problems. Make sure you want this before you install it, because uninstallation can be troublesome and maybe even impossible. Definitely check the readme.txt before installing.
NOTE: v2.2.2 was the last version for mobile processors.
Reboot twice after installing either or both of the above.
Check that DMA is enabled for your drives thus:
Control Panel -> System -> Device Manager -> Disk Drives
Go into Properties for each hard drive and then into the Settings tab. There should be a check box available for DMA. Check it and reboot. You can also do this for your optical drives.
Note: If you're using a PCI IDE or SATA controller, you may not be able to do this. I run a Promise Ultra 133 TX2 IDE controller in two of my 440BX PCs. Devices attached to the onboard controller have the option to enable DMA. Devices attached to the Promise controller do not.
