Can no longer exit MS-DOS Mode (to Win98)
Getting old software/games running on older hardware.
Postby infiniteclouds » 2017-5-23 @ 04:01
For some reason I can no longer exit DOS and return to Windows. I've been using Phil's .pif to load into DOS but now whenever I execute WIN or EXIT while it will still ask me if I want to leave MS-DOS mode to return to Windows if I input yes it just brings me back to Phil's Start Up menu for choosing a DOS/Mem/Hardware config. I can get into Windows 98 Safe Mode from there, but that's all.
Any reason this might be happening? I loaded a back-up of an older autoexec.bat thinking that it could have been something that was messed with in there when I was trying to get my 2nd sound card working.
infiniteclouds
Re: Can no longer exit MS-DOS Mode (to Win98)
Postby mrau » 2017-5-23 @ 18:05
whats in that file?
mrau
Postby infiniteclouds » 2017-5-24 @ 03:11
@ECHO OFF
REM Added by SetBlaster on Sat Jan 01 23:24:03 2000 [[My BIOS settings and clock reset every time I disconnect the power -- I've replaced the CMOS battery and re-seated it several times but it never saves if I have to unplug it]]
SET BLASTER=A240 I5 D0 H5 P330 E640 T6
SOUND=C:\DOSAWE
C:\DOSAWE\CTCM.EXE
C:\DOSAWE\DIAGNOSE /S
C:\DOSAWE\MIXERSET /P
C:\DOSAWE\AWEUTIL /S
SET BLASTER=A220 I7 D1 T4
GoTo %config%
:EMC
:XMC
:CMC
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D OPTICAL
:EM
:XM
:CM
LH C:\DRIVERS\CTMOUSE.EXE /R2
:E
:X
:C
IF EXIST C:\WINDOWS\DOSSTART.BAT CALL C:\WINDOWS\DOSSTART.BAT
REM
REM The following lines have been created by Windows. Do not modify them.
REM
C:
CD C:\
CALL C:\WINDOWS\COMMAND.COM
C:\WINDOWS\WIN.COM \WX
infiniteclouds
Postby Jorpho » 2017-5-24 @ 04:05
If you put REM before the IF EXIST line and before the CALL line, that ought to get you back int to Windows.
In fact, I did a Google search for "win.com /wx" (no quotes) and this was the first hit:
https://www.computerhope.com/issues/ch000140.htm
User avatar
Jorpho
Postby infiniteclouds » 2017-5-24 @ 04:36
D:
First I tried remarking just those two lines and it still booted into DOS... when I remarked all of the lines from the link you sent me it yielded the above error.
Also interesting is that if I select SHIFT+F5 to go to straight command prompt and type WIN from there I am told that HIMEM.SYS is missing -- however when I look in C:\WINDOWS it is in there.
I decided to take a look in HIMEM.SYS and much of the beginning of it was just a bunch of nonsensical characters. When I scrolled down I saw the following:
Shadow RAM is disabled.$<
WARNING: Shadow RAM disable not supported on this system.$7
WARNING: Shadow RAM is in use and can't be disabled.$3
ERROR: HIMEM.SYS requires MS-DOS 3.00 or higher.$:
ERROR: An Extended Memory Manager is already installed.
ERROR: HIMEM.SYS requires an 80x86-based machine.$1
ERROR: No available extended memory was found.$%
ERROR: Unable to control A20 line!$3
ERROR: VDISK memory allocator already installed.$(
XMS Driver not installed.
infiniteclouds
Postby Jorpho » 2017-5-24 @ 05:45
infiniteclouds wrote:Also interesting is that if I select SHIFT+F5 to go to straight command prompt and type WIN from there I am told that HIMEM.SYS is missing -- however when I look in C:\WINDOWS it is in there.
I don't think it means that HIMEM.SYS is "missing"; it probably means tht HIMEM.SYS isn't loaded. Normally it is loaded by CONFIG.SYS (as in DEVICE=C:\WINDOWS\HIMEM.SYS); it is not supposed to be a file that you are supposed to edit, ever. (The only .SYS files you are normally supposed to read are CONFIG.SYS and MSDOS.SYS.)
Do you still have a CONFIG.SYS? That is just as important as autoexec.bat; if you restored autoexec.bat but not config.sys, that would be a problem.
User avatar
Jorpho
Postby infiniteclouds » 2017-5-24 @ 06:04
I do have a CONFIG.SYS.
I did try editing the HIMEM file but I just broke things further -- despite restoring a back up of it. I can't select any Extended or Expanded memory load-outs now or the system hangs. I think my method of backing up/restoring my Autoexec is what screwed things up to begin with. Basically I had I just opened it with EDIT, Saved AS a .TXT file, then later on opened the .TXT and saved it as a .BAT.
My CONFIG.SYS:
DOS=SINGLE
[COMMON[
DOS=HIGH,UMB,NOAUTO
FILES=40
BUFFERS-40
LASTDRIVE=H
[menu]
menuitem=EMC, Expanded Memory + Mouse + CD -ROM
------ the rest here is just a list of memory load-outs from Phil's PIF.
[EMC]
DEVICE=C:\WINDOWS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\WINDOWS\EMM386.EXE RAM
DEVICEHIGH=C:\DRIVERS\VIDECDD.SYS /D:OPTICAL
[XMC]
[CMC]
[EM]
[XM]
[CM]
[E]
[X]
[C]
I copied over and replaced the entire WINDOWS folder from a back-up I made on my main computer. That fixed the hanging and issues with Expanded/Extended memory load-outs, but I still can't get out of DOS.
infiniteclouds
Postby Jorpho » 2017-5-24 @ 13:51
At this point I feel like I can only guess what you've done to your system. You should probably go back to basics and use a straightforward autoexec.bat and config.sys without any of these memory options. I don't even know why you'd want options without extended memory (that is, with no HIMEM.SYS); it's very unlikely you'd ever find a program requiring such a configuration.
infiniteclouds wrote:I think my method of backing up/restoring my Autoexec is what screwed things up to begin with. Basically I had I just opened it with EDIT, Saved AS a .TXT file, then later on opened the .TXT and saved it as a .BAT.
I don't know why that would make a difference as long as the filename is correct. Why not just just rename it from the command line, as in "ren autoexec.txt autoexec.bat" ?
[COMMON[
BUFFERS-40
I assume these are typos.
You probably need to make those edits to your autoexec.bat again.
User avatar
Jorpho
Postby infiniteclouds » 2017-5-24 @ 19:29
Yes, those are typos. Also, I remarked out those lines of the Autoexec.bat again and it makes no difference - there's still no escape. I'm going to just reformat and reinstall Win98. I was just hoping to figure out what happened for learning purposes.
infiniteclouds
Postby Jorpho » 2017-5-25 @ 00:26
As discussed in that page I linked to, you can also try changing the BootGUI line in MSDOS.SYS if necessary.
User avatar
Jorpho
Postby infiniteclouds » 2017-5-25 @ 00:43
Indeed - BOOTGUI was already = 1, however.
Thanks for all of the suggestions though, I do appreciate it.
infiniteclouds
Postby wbc » 2017-5-26 @ 15:20
Try to add "DEVICE=C:\WINDOWS\IFSHLP.SYS" in config.sys, afaik it sometimes solves VFAT init error BSOD (there also is msdos.sys switch which does the same but I can't remember it)
--wbcbz7
wbc
Return to Software
Who is online
Users browsing this forum: No registered users and 4 guests
