Blood resolution issue
First post, by fsmith2003
Does anyone happen to know if there is a way to start Blood v1.1 at a certain resolution? It always defaults back when I quit the game then reopen. Running W95 OSR 2.5 on a P2 300mhz.
Reply 1 of 1, by kaputnik
First check that blood.cfg in the game dir isn't write protected. You can set the resolution both from within the game and from setup.exe, try the way you haven't before. If it still doesn't work, you could try setting it by editing blood.cfg manually.
