Dos games on Geforce 2/4/5/6/7 and LCD in Win98SE, black screen in fullscreen mode..Geforce drivers 5x.yz + problem
Getting old software/games running on older hardware.
Postby ruthan » 2017-9-04 @ 23:46
Hello,
i started using my old Games machine, i want to run Warcraft I, but when i run it from Windows 98, its starting in fullscreen mode and i have got black screen on my 20" 1600x1200 LCD + Geforce 6600GT - 81.98 drivers,
when i press ALT+ENTER game is running fine in window mode.
In pure DOS 320x240 ganes are running fine, so its running it some other stranger resolution like 320x200 or where is problem? Some Powerstrip porn needed, how to check it?
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough HW.
User avatar
ruthan
Location: Schwarz Wald-from France to Ukraine, from Denmark to Austria. Celts+German+Slavs melting pot.
Re: Wacraft I on Geforce 6600GT and LCD in Win98SE, black screen in fullscreen mode, but i can get back to window mode..
Postby darry » 2017-9-05 @ 05:10
I have essentially the same issue with a 6600gt on 1600x1200 monitor over dvi in Doom in every driver version I have tried. I always believed it was a known issue, so I never inquired about it.
See http://www.flaterco.com/kb/DOS_W98SE_general.html
I seem to recall other references to this elsewhere .
Incidentally, if I Alt-Enter back to full screen I usually get an image . Try it .
By the way, on the same system over DVI, a Quadro FX1100 an FX5900 not not have this issue (both have a Silicon Image TMDS , whereas my 6600GT has an integrated one).
darry
Postby ruthan » 2017-9-05 @ 23:29
What about other Geforce 6xxx cards or Geforce 7xxx AGP cards, could someone test it? Im using DVI too, what about VGA?
I just tested Doom is the same.
User avatar
ruthan
Postby darry » 2017-9-06 @ 05:15
I have a non-GT Geforce 6600 that does the same thing .
Geforce 7xxx AGP
No official or beta Windows 9x/ME driver from Nvidia supports anything beyond the Geforce 6xxx . There are patched infs that apparently allow certain members of the Geforce 7 family or higher to somewhat work, but I doubt many people are using them .
what about VGA
I will try it when I get a chance, but by Geforce 6600GT is dual DVI and I do not have any DVI to VGA dongles handy (used to have a ton of them). The 6600 non-GT is somewhere in storage and might have a VGA port.
The best "solution" to the issue is likely to get a Geforce 5 series card (FX) or a Quadro from the same generation with a Silicon Image TMDS , or possibly to try VGA if that works for you .
I do not have any working Geforce 5 series cards without a Silicon Image TMDS on hand to test so I cannot comment on that .
darry
Postby ruthan » 2017-9-17 @ 00:36
I just test ATI X800 XL 256 MD and with same OS installation and monitor, Doom 2 and Warcraft are running fine.
Im using Geforce 7 and i know couple of people which are using them, best are 256 MB versions, but there is paid patch to make 512MB versions working.. Its working on 4 my machines, but i had one with AMD970 chipset where i had lots of nvidia dll erros, right from boot in explorer, but games are running fine.
User avatar
ruthan
Postby darry » 2017-9-17 @ 18:45
I've go an x800 GTO on the way . See viewtopic.php?f=63&t=55560
Does it have the same issue ?
darry
Postby ruthan » 2017-9-17 @ 19:21
Im not sure if Geforce 7 has this issue, but there are other for example when i start command.com in safe mode i got black screen and there is old shutdown issue, there are patches but they are not working for everymachine.
User avatar
ruthan
Postby ruthan » 2017-11-21 @ 01:38
Ok i did some testing Geforce 7 / 7600 / 7900 / 7950 - with 256 / 512 MB also has this issue.
Could someone test Geforce 4 / Geforce FX 5200?
User avatar
ruthan
Postby darry » 2017-11-21 @ 02:44
I briefly tested a TI 4200 and it did not have the issue, if I remember correctly .
My guess is still that Nvidia chips using an integrated TMDS will have the issue . If that it is the case, the FX 5200 is likely to be affected (have not tried it, as my FX 5200 and FX 5500 are in storage) .
darry
Re: Dos games on Geforce 6 / 7 and LCD in Win98SE, black screen in fullscreen mode, but i can get back to window mode..
Postby ruthan » 2017-11-21 @ 19:13
Maybe exist some settings to fix it, but with default driver / windows settings is not working.
I also dont know if it is LCD only issue, or it would be same with CRT monitor? My LCD is capable of 75 Hz, at least for some resolution.
I also discovered other issue on ATI side - X800 XL Gigabyte not give picture on LCD HP 24" 1920x1200 60 Hz monitoring at all (from boot black screen), with second DELL 20" 75 Hz is working fine - i have installed lastest Bios.
Reported even on Geforce 4...
User avatar
ruthan
Postby RayeR » 2018-12-28 @ 04:02
I have similar problem with 7900GT when switching a textmode dos window to fullscreen. Sometimes monitor goes black and show some weird frequency out of sync message. In such case I can press alt+enter to go back windowed and once more alt+enter to fullscreen again and it works then. It's some way random, I dunno maybe 20% of fullscreen swithches go wrong and I have to repeat.
Gigabyte GA-P67-DS3-B3, Core i7-2600K @4,5GHz, 4GB DDR3, 128GB SSD, GF7900GT, SB Audigy + YMF724F + DreamBlaster combo
User avatar
RayeR
Re: Dos games on Geforce 4/5/6/7 and LCD in Win98SE, black screen in fullscreen mode, but i can get back to window mode..
Postby ruthan » 2018-12-31 @ 16:59
Hmm, if it would be in 20% of cases, i would be fine, but for me it was 100%..
User avatar
ruthan
Postby Tiido » 2019-1-01 @ 00:04
From my experience this is a nvidia driver issue, with older drivers it doesn't happen but then you cannot use the better cards either...
User avatar
Tiido
Postby Laaca » 2019-1-01 @ 16:58
I face this issue for years. It can corfirm it in the GeForce 4MX and GeForce 2 MX400.
It happens with windows drivers 5x.yy.zz and up.
The last drivers without this bug are 45.xx.yy
Unfortunately these drivers lack some functions and can not run f.e. Operation Flashpoint
What is interresting is the fact that in can be avoided if the return from graphic mode into text mode is not just
"mov ax,3; int 10h"
but
"mov bx,3; mov ax, 4F02h; int 10h; mov ax,3; int 10h"
Maybe would be possible to write a small TSR which traps the INT10h/ah=0 and changes it in the way above.
Laaca
Postby RayeR » 2019-1-01 @ 22:02
Yes, for Win9x a such TSR could be loaded from autoexec.bat before win boots and active in every dos session. But not sure if it's not swithced by driver directly so TSR wouldn't have a chance to trap this...
User avatar
RayeR
Re: Dos games on Geforce 2/4/5/6/7 and LCD in Win98SE, black screen in fullscreen mode..Geforce drivers 5x.yz + problem
Postby ruthan » 2019-1-11 @ 23:52
So we need someone able to hack drivers on Win 9x level, i wonder are there such guys?
User avatar
ruthan
Return to Software
Who is online
Users browsing this forum: No registered users and 3 guests
