First post, by nPulse
Hi all, I've tried installing win98 several times now with different Chipset drivers. I can get everything working, the Ati X300 the sound, the USB 2.0 support and flashdrivers. But unfortunately there seems to be a USB input lag with the mouse and when connecting a USB Joystick.
It seems that the refreshrate of the mouse and joystick are very low, so it lags and I'm unable to play games with it. When using the mouse with Boot programs (on a usb boot disk) it just works ok..
Also when using updated chipset drivers for the sata controller it causes a unsolvable resource conflict and windows is unable to detect my dvd drive. I've tried allocating a different input but then system freezes..
Can someone please explain me what is happening? thanks1 😀
Reply 1 of 4, by cyclone3d
Exactly which USB drivers are you using?
Exactly which chipset drivers are you using?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by nPulse
I've used several different ones. For the USB and chipset I've used on different installations:
usb2098me.exe
269601USA8.exe
nfinst_enu.exe
infinst_autol.exe (This one gives a IDE resource conflict and disables my DVD drive)
Slipstreamable drivers: http://www.msfn.org/board/topic/163405-slipst … et-inf-drivers/
nusb33e.exe works and gives full USB 2.0 speed access to usbdrives. (I think)
Also vcredist.exe
Reply 3 of 4, by nPulse
Ok this is how I fixed it..
Install windows 98SE
Remove all PCI hardware in Device Manager. And move the contents from ICH6INF.ZIP (don't know where I found it) and copy this to c:\Windows\Inf
Reboot and let Windows install all devices
-Run usb2098me.exe, 269601USA8.exe, nfinst_enu.exe and vcredist.exe.
-Run nusb36e.exe
Reboot and the mouse works flawlessly!!
I've been messing with this the last 3 days, and installed Win98 more then 10 times in different configurations.. If anyone would like the ICH6INF.ZIP file I've used, just let me know!
Reply 4 of 4, by cyclone3d
Glad you got it sorted.
Could you attach the ICH6INF.ZIP to this thread?
YMF7x4 Guide
