First post, by Elia1995
- Oldbie
Hi, suddenly the escape key on my keyboards is not working anymore in the DOS mode or in DOS windows on my Windows 98 Pentium 3.
I tried several keyboards and none of them's escape key is working, otherwise the key works just fine in Windows 98 itself and in other programs, it's only in DOS programs that it doesn't work at all.
It's a very important key, because in configuration programs such as the setup.exe of certain DOS games, I can't go back in the menu, I can't even exit some games that bring the menu when you press ESC without having to alt-tab out of it or resetting the PC if it's in dos mode.
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
