How do you copy multiple files in DOS?
Getting old software/games running on older hardware.
Postby infiniteclouds » 2017-11-30 @ 06:55
XCOPY is great... except when you're dealing with larger games and smaller 720KB diskettes where you're not going to get everything you need in one XCOPY... leaving leftovers. I've been having to manually copy whatever leftover files on the next disk one at a time....
I've searched google.. and I've looked at COPY /? but I can't figure out for the life of me how to copy multiple SPECIFIC files at once -- WITHOUT combining them, mind you (as the [filename]+[filename] will do.
infiniteclouds
Re: How do you copy multiple files in DOS?
Postby keenmaster486 » 2017-11-30 @ 07:50
So you want something that will copy until the disk is full then ask you to insert the next disk etc?
I flermmed the plootash just like you asked.
Very silly indeed: https://audaxeundum.wordpress.com
User avatar
keenmaster486
Postby konc » 2017-11-30 @ 08:53
You can always use something like norton commander to select + copy the specific files you want
User avatar
konc
Postby infiniteclouds » 2017-11-30 @ 09:06
keenmaster486 wrote:So you want something that will copy until the disk is full then ask you to insert the next disk etc?
Yup. Or at least be able to list multiple files that I want to copy in one line, so I don't have to retype copy and destination each time.
konc wrote:You can always use something like norton commander to select + copy the specific files you want
I wouldn't have thought to use a separate program for copying files.
For now the workaround I've found is XCOPY with /P so that it will ask me Y/N for each individual file. This let's me hit N until I get to the last file that was copied, then spam Y. Sure I have to sit there and keep pressing N/Y but at least I don't have to type out the copy command and file names over and over.
infiniteclouds
Postby mrau » 2017-11-30 @ 09:36
where do You take the filenames from? is there a pattern here? is placing all filenames in a textfile first acceptable?
mrau
Postby dr_st » 2017-11-30 @ 09:40
infiniteclouds wrote:I wouldn't have thought to use a separate program for copying files.
Then please do. File managers exist for exactly this reason: to make dealing with large collections of files easier.
User avatar
dr_st
Postby derSammler » 2017-11-30 @ 10:24
RAR 2.0 for DOS. I'm using this for all my diskette-only retro systems. It does all the work for you and due to compression, will even use less disks.
derSammler
Postby Kubik » 2017-11-30 @ 12:17
Kubik
Postby Davros » 2017-11-30 @ 19:37
copy *.* c:\temp
copies all files in the current folder to c:\temp
xcopy c:\temp /e
copies all folders,sub folders and files in the current folder to c:\temp
User avatar
Davros
Postby Cyberdyne » 2017-12-01 @ 07:29
I say also i have been using Volkov Commander 4.0x for about 20 years for now. Latest is 4.05. And it has never failed me in any way.
It is my main shell in DOS. Usually i even launch all my games from there.
I am aroused about any X86 stuff that has full functional ISA stuff. I think i have problem.
User avatar
Cyberdyne
Postby Kubik » 2017-12-01 @ 09:01
Cyberdyne wrote:I say also i have been using Volkov Commander 4.0x for about 20 years for now. Latest is 4.05. And it has never failed me in any way.
Latest is something like 4.99 beta, it might even support long file names. However, for pure DOS, 4.05 is perfectly fine :)
Kubik
Postby infiniteclouds » 2017-12-03 @ 14:07
Thanks for all the recommendations. I now know the joy of using a file manager -- I discovered this machine actually had one installed on it (XTGOLD).
infiniteclouds
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
