Dr. Hardware Sysinfo (DOS) - Versions Archive
Getting old software/games running on older hardware.
Postby derSammler » 2017-12-25 @ 11:32
I've probably mentioned a few times before that Dr. Hardware is my favorite, and in my opinion best hardware info/benchmark tool for DOS. Unfortunately, old versions are virtually impossible to find these days. With some luck, you'll find 9.0e, but that's it. So I put all the versions online that I collected over the years, ranging from 1997 to 2007.
Here's the URL to the archive: http://retro-net.de/drhard/
Note that "e" in the file name stands for English, "d" for German. If someone can provide additional versions, please get in contact.
derSammler
Re: Dr. Hardware Sysinfo (DOS) - Versions Archive
Postby clueless1 » 2017-12-25 @ 11:49
Thanks!
User avatar
clueless1
Postby Tronix » 2017-12-25 @ 11:50
Version 3.7 there: (Link removed: no warez on Vogons please!)
User avatar
Tronix
Postby derSammler » 2017-12-25 @ 12:10
Tronix wrote:Version 3.7 there:
Thanks, but that version is registered/cracked. Also, files are missing (BENCHCMP.DAT).
derSammler
Postby Dominus » 2017-12-25 @ 12:18
What is the status of this software? Are you allowed to host it, is it shareware etc?
@Tronix: link to cracked software removed - please don't post that on Vogons
User avatar
Dominus
DOSBox Moderator
Postby derSammler » 2017-12-25 @ 12:22
Yes, it's shareware. I'm only hosting shareware versions.
derSammler
Postby Dominus » 2017-12-25 @ 12:23
All right then! Sorry for having to check ;)
User avatar
Dominus
DOSBox Moderator
Postby BSA Starfire » 2017-12-28 @ 20:01
Thanks for sharing, this is a really nice little DOS utility, great for benching old video cards.
386SX 33MHz,4MB Ram,ALi M1217 motherboard,OAK OTI077 1MB. Seagate ST1144A.
386DX 25MHz,IIT 387,8MB RAM,Opti,32K cache,WDC90C30 512K.Conner CF170A.
IDT Winchip C6 200MHz,DFi P5BTX/L,Number Nine S3 ViRGE 2MB,SoundBlasterCT2260,1.2Gb Fujitsu.
User avatar
BSA Starfire
Postby derSammler » 2017-12-29 @ 17:14
Version 6.5e added to the archive.
derSammler
Postby clueless1 » 2017-12-29 @ 17:18
Is there a version that is best for specific systems? Is there any reason not to choose the latest version on any DOS system, no matter how old?
User avatar
clueless1
Postby derSammler » 2017-12-29 @ 17:25
No, I mostly use 9.0 as well, as it's more stable when detecting hardware. Older versions however are somewhat better when it comes to benchmarking, as they compare with systems of the time. 9.0 e.g. compares system speed against a PIII 667 Mhz, which is quite pointless on a 286. And for video benchmark, 8-bit VGA was removed and AGP added in later versions. But these are only cosmetical things and not related to the actual results.
derSammler
Postby derSammler » 2018-3-05 @ 18:15
Version 3.7d added to the archive. If someone has the english shareware release of that (3.7e), please let me know!
derSammler
Postby cyclone3d » 2018-3-05 @ 19:50
Awesome. I used to use that way back in the day. Just posting in here so it saves it to my threads list.
User avatar
cyclone3d
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
