First post, by Arbys Guy
well i pulled a Z100ATAPI zip disk drive out of a recent haul i got and was trying to install drivers under windows 98 se on a asus a7v133 rev1.05
i downloaded IomegaWare Tools 4.02 from http://www.vogonsdrivers.com/getfile.php?file … &menustate=34,0
but the first time i attempted to install it it froze on updating driver library, the second time after uninstalling from add/remove it worked but the drive is not showing up in my computer. when i put a zip disk in the drive the light flashes and then stops. ive never installed a zip drive before, i was a bit naive i thought windows 98 se would have drivers preloaded for it.
The drive does show up when i boot the computer so the motherboard is detecting it. but windows does not detect it to my knowledge, there was no new hardware wizard pop up or anything .
this motherboard has VIA chipset ive heard lots of bad things, should i just try on another motherboard?
[/url]
