First post, by Demonslayer2103
I have been having a problem with the talkie versions of both Indiana Jones and the fate of Atlantis and monkey island talkie edition the games have a problem where they will sometimes freeze until you press f5 then exit the f5 menu then it will start working then it will freeze later and the same trick will work I also have a problem in monkey island 1 where the sound has static my computer is a hp d530 with a Pentium 4 running windows 98 se but I run the games in dos mode any help would be a great 😀
