First post, by telecommand
- Newbie
I have a couple of old PC booter 3.5" disks I want to back up, as I'm terrified they'll become unreadable any time now. Since you can't just read the files in Windows/DOS etc. is there a way to copy the disk into an image file, or at the very least duplicate the disk to a newer floppy to use when I want to play them (thus preserving the originals for a little while longer?)
I did a little searching and saw there was a program called "CopyIIPC" - is this the best route to go? Or is there a newer/better method to use? I read that CopyIIPC doesn't run well on anything faster than a 286..?
