First post, by GabrielKnight123
Can PLOP boot manager boot from a file or is it just a partition loader? I have Dos 6.21 loading from a primary partition in PLOP but when I install Windows 3.11 on the same partition can I point PLOP to boot the Win.exe or Win.com file (I forget which it is) to start Windows? I could use a menu in dos before it loads Dos to have a menu selectable with Dos or Windows but I like the PLOP menu and would like to use it if it can.
Reply 1 of 2, by dr_st
Even if you could boot from a file, Win.com is not a bootable image.
Reply 2 of 2, by keropi
Nope PLOP does not offer this functionality but you can just add win.com at the end of your autoexec.bat and load it this way - which incidentally is the way you are supposed to load win3x
