First post, by digitalx
I have a Riva TNT2 on a WIn98 SE machine. The game installed via disc but the menu is blank, there is no options just the background image.
Upon initial load it had flickering lines which has now subsided. I have the 71.84 graphic card drivers installed via CD. What could be causing this menu malfunction?
Running in 1024x768 32 bit colour.
As for tony hawks pro skater 2, it loads up to a black screen then exits.
PC Specs:
HP D350: WIn98 SE/256MB RAM/Celeron 2.6Ghz/RivA TNT2 64/64 Pro
I have an Asus P4S8X with a P4 and 512MB RAM if changing that would help?
