Crash and dump in DOS mode
Getting old software/games running on older hardware.
Postby vmunix » 2018-11-29 @ 13:27
Guys, have any experience this problem, I'm running Sam & Max (if you haven't recognized it in the screenshot) and randomly the program terminates and get a stack register dump, Sam & Max runs in DOS protected mode (DOS/4WG).
Other specs are:
Happens either booting from a floppy or booting Windows 95 first then rebooting into DOS real mode (Not DOS box)
Computer is interesting a Cyrix 486 DLC 40Mhz with math coprocessor, 32Mb and Opti SLC chipset., Diamond Speedstar ISA, SCSI drives and of course Turtle Beach sound card, but I don't think is that hardware related, BIOS settings perhaps ?
Trailing edge computing.
User avatar
vmunix
Re: Crash and dump in DOS mode
Postby Jo22 » 2018-12-04 @ 05:47
Interesting. Does it also happen if EMM386/QEMM/etc. is not loaded ? :confused:
Edit: Maybe unreleated, bui Phil has some Cyrix utilities on his page.
Maybe changing cache/register settings helps.
His page is available at https://www.philscomputerlab.com/
Edit: Here's the Cyrix part of the page (these modern menues can be quite confusing! :sweatdrop:)
https://www.philscomputerlab.com/cyrix-486dlc.html
User avatar
Jo22
Postby yawetaG » 2018-12-04 @ 06:27
Does it also happen if you use one of the alternate DOS extenders? DOS/4G(W) programs never were the epitome of stability (crashes are quite common), and it's possible to replace the extender by something else:
https://en.wikipedia.org/wiki/DOS/4G
yawetaG
Postby vmunix » 2018-12-04 @ 13:36
Thanks guys, I will check your suggestions, I've been playing DOTT flawlessly in the samemachine however I don't remember if that game uses protected runtime, I will check when I get back home, I also was suspecting on the Cyrix internal cache, and I've even replaced a BB (quite rare) version of the DLC for a AB. Oh well I think I'm having this same issue, I was wondering if anyone using a Cyrix DLC/SLC had reliably run stuff in DOS/4WG mode
viewtopic.php?f=46&t=45011
User avatar
vmunix
Postby yawetaG » 2018-12-04 @ 20:52
vmunix wrote:Thanks guys, I will check your suggestions, I've been playing DOTT flawlessly in the samemachine however I don't remember if that game uses protected runtime, I will check when I get back home, I also was suspecting on the Cyrix internal cache, and I've even replaced a BB (quite rare) version of the DLC for a AB. Oh well I think I'm having this same issue, I was wondering if anyone using a Cyrix DLC/SLC had reliably run stuff in DOS/4WG mode
Having run the same DOS/4GW games on two Cyrix processors in the past (486 DX 40 and DX2 80), I never noticed much difference with running them on a genuine Intel CPU - crashes seem to be mostly related to bugs in the games themselves.
Ignoring faulty memory modules, that is.
yawetaG
Return to Software
Who is online
