Half Life 2 stutter issue
Getting old software/games running on older hardware.
Postby buckeye » 2018-12-03 @ 14:12
Just noticed this when the trains go by in a scene everything slows to a crawl. My XP rig (see my sig) should have enough muscle for this game, is this a bug and if so is there a patch for it?
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W XP SP2
Asus P3B-F P3 850 512MB 40GB Hercules 3D Prophet II 64MB Voodoo2 SLI Aureal Vortex 2 400W 98SE
User avatar
buckeye
Re: Half Life 2 stutter issue
Postby Kerr Avon » 2018-12-03 @ 22:57
Sorry, I can't help, but I do know that over the years Valve have improved (or at least altered) Half-Life 2's program and data, so perhaps you're using a newer version of the game, that needs more resources than your PC has?
Kerr Avon
Postby odey123 » 2018-12-15 @ 04:10
Yeh, if its not a version problem then possibly a settings problem? you are correct your hardware as far as i can tell should be able to slay this game. Vsync? what monitor is being used? what refresh rate? programs in the background?
odey123
Postby Fusion » 2018-12-15 @ 21:44
I have a version of HL2 from 2004 that runs like a dream on my A64 3800+/2GB DDR RAM/ X800XT PE 256MB @ 575/575 @ 1080p max settings. No stuttering just the odd dip to the high 30s when in a busy area. Newer versions added a lot to the engine that will kill performance on older cards of the era.
P3 800 | 512MB PC100| PCI V3 3000 16MB @ 195/195 | CT4780 SB Live! Value| WinME
P3 450 | 128MB PC100| AGP TNT2 Pro 32MB | CT4170 SB16 | MS-DOS71
A64 2.4 | 2GB DDR1 | PCI-E Radeon X800XT @ 575/575 | CT4780 SB Live! Value| Win2K
User avatar
Fusion
Postby leileilol » 2018-12-16 @ 02:41
The original 2004 build did have a lot of sound cache related stutter though...
Voodoo2s aren't 100mhz stock
Geforce256 isn't released as a beta on New Years '99 under the Quadro brand
DOS gaming isn't a bilinear 320x200 16:10
DOS PCs aren't better than the Macintosh
DOSBox is not for running Windows 9x
SGL != Glide
User avatar
leileilol
Return to Software
Who is online
Users browsing this forum: K1n9_Duk3 and 3 guests
