building a 233MMX/Voodoo 2 rig.. what's the last era of games would this cover?
Getting old software/games running on older hardware.
Postby DaveJustDave » 2019-1-07 @ 17:55
Not sure if this should have gone in the hardware sub or the software sub..
So inspired by philscomputerlab's 1 in 136 build, I'm building a "do-it-all" machine that will pick up where my 286 left off (using setmul to downclock the machine and save desk space by retiring a 386, 486, and P75 machine).
I'm just wondering how far into the 90s (or even the 2000s) this would carry me..
specs:
- biostar mb-8500TTD socket 7
- pentium 233mmx overclocked to 266
- 64MB ram
- adaptec 2940uw PCI SCSI + 10kRPM drive
- ati mach 64 PCI
- diamond 3dfx voodoo 2 PCI
- matrox M3D powerVR
- GUS MAX
- AWE32 ISA PNP
- DOS 6.22 and Win98SE
It's honestly been so long, I have a huge hole in my memory regarding this era of gaming. I'm thinking right around Freespace 1 and 2? But that feels a bit off.
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
User avatar
DaveJustDave
Re: building a 233MMX/Voodoo 2 rig.. what's the last era of games would this cover?
Postby gdjacobs » 2019-1-07 @ 20:15
The only issue I see with this build is the m3d card. It will benefit greatly from a much stronger CPU, so I'd save it for a higher end Win98 build. Other, earlier accelerators like the Voodoo 1 and perhaps Verite cards have better DOS support.
User avatar
gdjacobs
Postby appiah4 » 2019-1-07 @ 20:40
Freespace 1 and 2 came in 97/98 and are more PII/K6-2 era games if you want decent acceleration.
MMX/Voodoo 2 is a fun combination but it kind of has no legs for stuff beyond 1997; so stick to Quake 2 and before or upgrade it to a K6-2/400 I would say.
1989:A500|1M|ACA500+|C1084S
1992:HIPPO-VL+|U5SX-33|8M|GD5428|CT2290|S2
1995:P5I430VX|P133|32M|T64+/MX2|V1|CT3980/32M
1998:MI5VP4|K6-2/400|128M|V2-1000/SLI|CT4500/32M
2001:GA-6OXT|P3-1200|384M|GF3Ti200|MX300
2004:K8VD|3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby gdjacobs » 2019-1-07 @ 22:00
I advocate going all the way to Athlon or better for a high performance DOS system, generally doing dual duty as a Win98 machine. PMMX based machines have superb flexibility which makes them wonderful DOS machines covering the performance range from 386DX to early P2. Most high performance DOS titles have some kind of frame limiter which eliminates clock matching issues found in pre-Pentium titles.
User avatar
gdjacobs
Postby DaveJustDave » 2019-1-07 @ 22:29
gdjacobs wrote:I advocate going all the way to Athlon or better for a high performance DOS system, generally doing dual duty as a Win98 machine. PMMX based machines have superb flexibility which makes them wonderful DOS machines covering the performance range from 386DX to early P2. Most high performance DOS titles have some kind of frame limiter which eliminates clock matching issues found in pre-Pentium titles.
I have a 1ghz Pentium 3 for my next step up.
Below that I have a Pentium II 400
Also have a bunch of k6-2 CPUs just need a super socket 7 motherboard.
I just wanted some clear demarcation on which games stop at this machine and start at the nexr
User avatar
DaveJustDave
Postby clueless1 » 2019-1-08 @ 00:49
I agree with appiah4. 1997 is the latest year I'd install games from. The 233MMX will bottleneck the V2 even there. Games like Quake 2, Tomb Raider II, Wing Commander Prophecy, and MDK should run okay. The Voodoo2 will be a better fit for your P2 400.
User avatar
clueless1
Postby leileilol » 2019-1-08 @ 01:27
2000 at most, likely. All that new gen UE1.5 and Q3 engine stuff is a 6th gen CPU flusher.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby gdjacobs » 2019-1-08 @ 18:28
Well, to answer your question, I'd say 97-98 with the last DOS titles.
User avatar
gdjacobs
Return to Software
Who is online
