Need some assistance installing CT Mouse in DOS in Win 98SE
Getting old software/games running on older hardware.
Postby jforrest1980 » 2019-1-11 @ 04:50
I am attempting to install CTmouse into DOS. This is my first attempt at something like this, so I really need some detailed instructions. I have read over the CTmouse documentation, and I am not seeing any step-by-step information on how to install. This will be on a Windows 98SE machine, which I will boot into DOS for the install. I will also be using a GOTEK Floppy drive emulator.
So I have my floppy emulator drive installed, and I have the software with a ready formatted USB stick.
I downloaded CTmouse 2.1 from here http://cutemouse.sourceforge.net/
Here is where I start to get confused. I extracted the file, and there are 3 folders in there "BIN, Doc, & Source"
1. Do I copy/paste all 3 of those files to a floppy file, or is there a specific file I need to install?
2. Do I just copy/paste, or do I need to save the file to the GOTEK floppy file as a "image"
3. Once I finally get the correct files on the floppy USB, what are the steps exactly once in DOS to get this installed? I understand how to navigate folders in DOS, but once I am in the floppy directory, I am not sure what to do.
Thanks in advance.
jforrest1980
Re: Need some assistance installing CT Mouse in DOS in Win 98SE
Postby deksar » 2019-1-11 @ 12:48
Have you tried:
Downloading cutemouse21b4.zip, extract it and inside "bin" folder, copy ctmouse.exe into C:, like it'd be: c:\ctmouse.exe (You'll only need this file)
and then add the following line into your autoexec.bat file:
C:\ctmouse.exe
and restart your system, try a DOS game/application that uses mouse.
Spectrum Holobyte's Super Tetris is a good sample to try.
deksar
Postby oeuvre » 2019-1-11 @ 14:31
or EDIT.EXE in DOS 6.x
HP Elite 8300 CMT i7 3770, 16GB, GTX750, 2xSSD + HD, XP/7/macOS 10.13
User avatar
oeuvre
Postby GigAHerZ » 2019-1-11 @ 14:41
oeuvre wrote:or EDIT.EXE in DOS 6.x
Isn't it edit.com?
And it should exist since DOS 5.
User avatar
GigAHerZ
Postby oeuvre » 2019-1-11 @ 14:44
ah right my bad! thanks
User avatar
oeuvre
Postby jforrest1980 » 2019-1-13 @ 16:09
Got it working folks. Thanks!
jforrest1980
Return to Software
Who is online
